Results 1 to 7 of 7
Thread: Powerflex rear- Update: NOT suitable for E32 740-750 and E34 M5
    May 2018
    UK
    has anyone experienced issues with polly bushes on the rear swing arms on 740 750.? Only these two models have ‘track widening’. I see an issue with extra strain on the dog bones as it tries to pull the track wider.??
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    Wouldn't the control arm prevent that?
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    May 2018
    UK
    I’ve asked this now on two forums,with PF directly and the supplier.
    i cannot be the only person that has thought this through and asked the question.??
    Nov 2012
    You might be. First if it is on the rear and you are applying power I would think that the force would be in and towards the rear. Anyway I recently was working on an exhaust issue and was using a product hyped on tv to protect to a certain level. It is a heat shield product and you can find it all over the web, youtube, tv, but when I contacted the manufacturer and asked for the data since I needed to know how much heat it actually passed through, they said the did not know! So I asked for the tests, they said there are none. i told them that if I was an attorney I would be having some fun. I guess the bottom line is that if you do not know, cant confirm, and aren't sure then stick with oem and call it a day. Best of luck!
    May 2018
    UK
    This is the correct operation of 'track widening' i fail to see how it can work once the powerflex bushes are stuffed onto the spaces.
    This is just me lifting the suspension in its normal way and the pitman arm is pulling the track wider.
    May 2018
    UK
    In case anyone is still reading this Powerflex have just agreed the bushes are NOT suitable for E32 740-750 and E34 M5
    and have also amended the details on the website.
    Nov 2012
    Good for you for sticking with this and getting it resolved.
  1. Powerflex or Stock rear subfrmae bushings
    By TYE in forum 1992 - 1999 M3 (E36)
    Last Post: 01-16-2007, 09:45 PM
  2. Update to rear rub issue; opinions?
    By berserkr in forum 1992 - 1999 M3 (E36)
    Last Post: 09-25-2003, 06:41 PM
  3. fs: powerflex rear trailing arm bushings (rtab's)
    By jww///95 in forum BMW Parts For Sale
    Last Post: 02-03-2003, 09:54 AM
  4. Anyone installed Powerflex Rear Beam bushings?
    By Erik@EDGE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-17-2002, 10:38 AM
  5. Update on rear suspension klunking, 95 M3...
    By madsedan in forum 1992 - 1999 M3 (E36)
    Last Post: 09-16-2002, 12:17 PM
