Results 1 to 17 of 17
Thread: E34 525 TDS Eibach B12 Sportline front strut wont fit
    May 2018
    Romania
    E34 525 TDS M Pak
    Unhappy E34 525 TDS Eibach B12 Sportline front strut wont fit
    Hello guys, i'm from Romania, and new here. I own an e34 525 tds, and recently i buy Eibach B12 Sportline kit, springs and shock absorber, but i need some help with front strut mount and type.
    My front shock absorber are: Bilstein and i have two part code on box:
    34-030202 and P36-3020.
    My question is, what front strut model to choose, and where from ?! Recently i bought originals from Germany with 300 euro part code: 31 33 1 134 096 but wont fitment, and i cannot return items. So i want to choose good fitment for me.
    I'll attach you some photo.
    https://imgur.com/a/peqUxrc
    Thanks.
    Oct 2003
    Seattle
    99 M3
    Use realoem.com with you VIN to determine factory part number(s), then use those numbers for strut and Guide Support/Bearing Plate to ‘shop’ for replacement parts.
    What model and build date are you working on?
    May 2018
    Romania
    E34 525 TDS M Pak
    Quote Originally Posted by bluptgm3 View Post
    I know about realoem, but there for my car are 3 differents struts mounts...
    e34 525 tds 94', WBAHA91030 GK35841
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Mar 2014
    Quezon City, Philippines
    '89 535i/5, '88 735i/5
    You need the later shock mount version with the larger hole. I ran into this problem too on my E32 project.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by mihu94 View Post
    The Guide Support is p/n 31331139437. The are two others but those appear to be collision repair parts.
    The greater issue is that there appears to be three strut casings and three different inserts. I gather they should all fit the Guide Support properly.
    May 2018
    Romania
    E34 525 TDS M Pak
    I bought 31331139437 as you say, but still wont fit.
    They are wide, the shaft moves inside the flange, and is still too high. I need a shorter flange to hold the nut.
    Please help me, I'm sitting with one month's dampers and I do not know what to order.
    They are wide, the shaft moves inside the flange, and is still too high. I need a shorter flange to hold the nut.Please help me, I'm sitting with one month's dampers and I do not know what to order.
    Hamburg, NY USA
    e23, e32, e34, e39
    Can you post a picture of how it sits as you would install it?
    Mar 2014
    You've got the mount upside down.
    moroza's Avatar
    BFE
    E34T
    The mount is upside down, and it looks like the shock is the early version that's 12mm wide at the top, not 14.
    May 2018
    Romania
    E34 525 TDS M Pak
    Oh, sorry for upside down photos.... if you know and it help, tell me, or draw in last photo what to measure with callipers.
    moroza's Avatar
    BFE
    E34T
    Ignore my previous post regarding thickness. I checked the Bilstein part number and it shows you need the v.3 strut mounts 31331139452. They are common to E30 and other cars, so cheaper and easier to find than E34-specific v.1 and v.2 (31331134096 and 31331139437, respectively).
    May 2018
    Romania
    E34 525 TDS M Pak
    https://www.ebay.com/itm/301768237082?ul_noapp=true
    This is the shocks pack i bought if can help you.
    Please help me, i'm rly newbie in "cars tuning", shop and others... and i already spent 400 euro on wrong stuts, and watching my shocks by 35 days so i want to put on the car
    moroza's Avatar
    BFE
    E34T
    That item listing is not useful, because the photo is all wrong (generic, not E34-specific) and the Bilstein numbers aren't present. Based on the Bilstein number you posted before - 34-030202 and P36-3020 - you need v.3 strut mounts 31331139452.
    May 2018
    Romania
    E34 525 TDS M Pak
    Sorry, still me. I dont have not solved the problem. In conclusion, I have the following flanges numbered in the photo as follows::
    1. 31331139452 (aftermarket - almost fit, the distance between the screws is too small)
    2. 31331139437 (aftermarket - similar to the original ones - do not match)
    3. 31331134096 (original bmw - do not match)
    In conclusion, none of the above sets fit, but Number 1 is the closest.
    I await opinions and help. Thank you
    https://www.bavauto.com/bmw-suspensi...-ske346016bil/
    This is the kit i own !
    Dec 2004
    CT, USA
    e28, e34, e39
    These mounts should fit. Do you have the spring plate #8 and washers #6 & #7 that goes with the mount?
    http://bmwfans.info/parts-catalog/E2...g_parts/#pos_1
    demet
    moroza's Avatar
    BFE
    E34T
    Did you try rotating it? The triangle formed by the studs is isoceles, not equilateral. Triunghi isoscel, nu echilateral. If it still doesn't fit the car body, but the others do, then these are just defective parts.
  1. strut cap wont fit over insert?!?!?
    By playmakr in forum 1983 - 1991 (E30)
    Last Post: 02-23-2004, 12:09 AM
  2. I Just Bought some Eibach Sportline Springs
    By Bimmer325 in forum 1991 - 1999 (E36)
    Last Post: 05-11-2003, 07:09 PM
  3. FS- Eibach Sportline Springs for 318i or is 100usd!!!
    By Dinan3 in forum BMW Parts For Sale
    Last Post: 02-19-2003, 12:40 AM
  4. looking for an e36 with Eibach sportline springs?
    By mkalle1 in forum BMW Rides & Events
    Last Post: 01-02-2003, 12:21 PM
  5. FS Eibach Front Strut Bar E36 $140
    By GQ_Style in forum BMW Parts For Sale
    Last Post: 11-29-2002, 08:15 PM
