Results 1 to 8 of 8
Thread: Fuel pump pinout
    May 2018
    UK
    Fuel pump pinout
    Hi, can anyone tell me the pinouts for the fuel pump,I need to run it up to drain the tank(tank is out)
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    I had a diagram but can't find it. The only thing in there is the pump(s) and the sending unit. You can try opening the sender and checking continuity of the wires to the pump and that will give you the pins you need to put 12v on
    Sent from my ONEPLUS A3000 using Tapatalk
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Oct 2007
    Boca Raton, Florida
    Try this
    May 2018
    UK
    Excellent thank you, I have a broken vent line so I need to drain it for repair of some kind.?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    there is a drain plug at the bottom of the tank http://www.realoem.com/bmw/enUS/show...diagId=16_0012
    May 2018
    UK
    I don’t have a drain plug, tank is out I would see it if it was there.��
    Jan 2005
    Japan
    Apparently depends on built year, my 11/88 tank has a drain plug, last year I parted a 11/93 750iL with a 90 ltr tank which did not have a drain plug.
    Oct 2007
    Boca Raton, Florida
    We're you still unable to run the pump? Mine has the drain plug on the passengers side of the cars tank.
  1. fuel pump
    By paul e in forum Forced Induction
    Last Post: 11-09-2003, 10:03 PM
  2. AA fuel pump
    By mrdoenutz in forum Forced Induction
    Last Post: 10-29-2003, 12:06 AM
  3. Can Engine Get Damaged from Fuel Starvation from Fuel Pump Failure?
    By dave162 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2003, 01:15 PM
  4. fuel tank line came off the fuel pump
    By tybmw in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2003, 01:43 AM
  5. Will a m3 or a 2.8s fuel pump fit into a 1.9?
    By J10B in forum Forced Induction
    Last Post: 01-14-2003, 10:52 PM
