Up for sale is my '99 M3 5MT coupe, Cosmos exterior, Black leather interior
I purchased this car in late 2015 with 108k miles. It's currently at 113.5k miles, only driven on nice days, no salt or winter. The car itself is in great shape with no rust and only a few smaller than dime-sized dings. The clear coat is still in great shape for its age.
I've put a considerable amount of money into the car over the last 2.5 years taking care of all of the typical e36 weak points and mildly upgrading a few things.
Reason for sale is that my growing family leaves me with not much time to actually drive and enjoy this car.
Basics:
Powered vaders, all functions working, leather is in great shape for its age
18 button on board computer, all functions working,
A/C blows cold, Heat blows hot
No transmission grinds, gear pop out issues or clutch slip
Sunroof fully functional
Recent (8/2017) compression test of all cylinders showed very even compression across all cylinders
1-170psi, 2- 170psi, 3- 170psi, 4- 165psi, 5- 170psi, 6- 165psi (#s are engine cold)
Work list:
Mobil1 0W-40 Euro formula every 6mos
ECS magnetic oil plan plug
OEM radiator and hoses
OE thermostat and metal housing
Stewart performance water pump
Cooling fan delete
Hard-wired A/C auxiliary fan to switch in cabin
FR/RR Brembo blank rotors
OE FR calipers
OE FR brake lines
FR/RR Hawk HPS+ pads
ATE 200 brake fluid
OE FR wheel bearings
OE serpentine belt
OE AC belt
OE Valeo alternator
Z3 steering rack (rack doctor) with new OE tie rod endsOE steering hoses and resevoir
OE steering shaft coupler
OE clutch pedal and bushings
Red line MT fluid
ECS stainless clutch line
OE RTAB bushings w/ limiters
Reinforced RTAB pockets
RR OE trailing arm ball joints
RR Camber-adjustable lwr control arms
RR OE upper control arm bushings
RR sway bar subframe reinforcement kit
RR sway bar stabi links
RR OE diff bushings
ECS poly diff bushing (front position)
Redline diff fluid
ECS magnetic diff fill plug
OE X-brace chassis reinforcement
Power flex poly control arm bushings
FR - Koni adjustable inserts in OE housings with 450lb hyperco springs, vorshlag camber plates
RR - Koni adjustable (911 fitment) with ground control reinforced upper mounts
H&R 28mm front sway bar with adjustable end links
OE Driveshaft center support bearing
Kosei 17X8.5 wheels w/ Dunlop 235/40/17 Star Spec II (tires will need replaced in the next few thousand miles)5mm spacers all around w/ extended lugs
Reupholstered headliner
Previous owner work:
Glass lens HID headlamps w/ Halo rings
Pioneer stereo head unit w/ aux input
Wired OPN
UUC SSK with DSSR rod
Borla cat-back exhaust
Link to pics: https://drive.google.com/drive/folde...v6kyVKJtZWf_Gy
Car is going into the detailer soon for a full exterior/interior treatment.
Clean title in hand. Asking price is $13.5K, I have well over 20K total invested in this car.
If you have questions, ask away!
Bump for new price. 11,500 OBO
Bump, check the pics link for a copy of Blackstone oil report, clean bill of health.
Still available?
