Hello guys i have a few questions i hope you guys can help me
1. I would like to remove the rear seats but how do i get the rear headrest out there electric?
2.As you can see from the first picture the rubber around the chrome trim outside the car is almost gone but the part itself cost upwards 150 is there some replacement rubber i could find online?
3.My pdc sensors stopped working a little while ago now my monitor has stopped working and the lights on pdc e sdc dont come on anymore what could be the issue?
Any help would really be appreciated.
Go to YouTube and type in 740/750 rear sear removal. It should answer all your questions.
Lets get the party started before it's my bedtime.
I know the rear headrests are removed just like the standard ones, just pull straight up and they should pop out. If they are anything like the 95 750 I pulled parts from the will not want to come out.
Sent from my SM-N950U using Tapatalk
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
thx for the replies guys ill give it a try how about that rubber around the trim any idea if theres any aftermarket stuff?
Also to add, it looks like is a fuse out for your control panel and your monitor.barring that it's one of the main junctions that has deteriorated. Post up if anything else went down at the same time.
Unless you have a very good reason to remove the seat backs, I wouldn't recommend it. To accommodate the electric movement, there is a hinged assembly at the top between the seat and rear parcel shelf. This mechanism is relatively fragile and easy to break.
PDC went down first then the lights for PDC then the monitor would come on and off until completely off I also wanted to ask is there any touch up paint or spray paint for my Interior trim the color of th leather and trim is Sandbeigr the leather is fine I need something for the plastic.
