I'm specifically looking for responses from individuals who have:
- S52 Engine (Not S50, M50, M52)
- Vortech V-2 SQ Si-Trim Supercharger
Can you please help me out with the following information?:
- What pulley combination are you running?
- What boost levels are you seeing at redline?
Thank you in advance for your help!
Jonathan Thayer
I have a new Si-trim with the 6.00"/3.00" combo and all the mods noted in my signature and am seeing 13 psi, same as it was with the S-trim.
hey chikinhed, could you post info on your latest dyno?
6.3 in crank 3.33 SC pulley. 12.5 lbs at redline.
Sias Tuned, Vortech Blown, 3.2L S52...456WHP/360WTQ
Sias Tuning | HowertonEngineering | Davis Motorsports Club
Jonathan....
www.aspracing.com
makes custom pullies for our cars..very nice..they cost $90-$95 each..any size you want....I had them make me a 2.90 for my V1 T trim....( always based off Ford Mustang pulley..if they ask)
Marco
2008 335I Space Grey,Black leather, Steptronic
Vishnu Procede V3 (16-17 lb boost) ,AA FMIC,AA Discharge tube/BOV,AA Downpipes,AA Race Exhaust, AFE Elite intake,BSH catch can, OS Giken LSD, PSS10 suspension, H&R sway bars, Motorsport CF strut brace, Stoptech BBKS, Forgeline ZX3S 19 x 8.5 front and 19 x 9.5 rears w/P235 35 19 fronts and P275 30 19 rear Conti Extreme DW's,Motorsport alcantara digital steering wheel, P3 boost gauge..etc
2011 X3 X-Drive 35i, Mineral Silver, Oyster leather
Hartge Power Pack tuner, H&R sport springs, Forgeline DE3S 19 x 9 Conti Extreme DW P245 45 19 all around, Supersprint Exhaust
AA Preferred Dealer
AA Preferred Dealer
I am thinking 15 but might be closer to 20 at 8K. s52 with RMS 2+ contact Chris Reese(thatdonfc) they just posted with their new two piece crank or Osh at RMS,
that is probaly right...or very close....you spin at ~ 48,300 RPM at 7000 with your V2....~ 12 lb boost....
I spin my V1 at ~ 49,800 RPM and make ~ 12.5-13 max lb boost on a warm day....
There is no definitive data on how much boost you should make..just a ballpark...between flow vs backpressure...
as I said....If you see 12 at redline..that is probaly right or very very close...
you are looking for nothing.....
Who is going to tune for that?? 20 lb boost at 8000 RPM?
AA Preferred Dealer
I'm looking at a compressor map right now and there's no way in hell that you'll make anywhere close to 20 psi with a V-2 Si.
If my math is correct, you'll max out at 16.9 psi overdriving the blower to 55k RPM.
Thanks Marco. I guess I'm just OCD.
Car is running like a champ after the Bosch 040 fuel pump install. Still throwing the CEL due to fuel adaptation limits - just need to get it read to see if it's now overfueling.
Miller Performance I believe, OSH said he could do it, and I believe him, otherwise I will be calling, Nick, or Mike R. Marco, that is with the new engine. The Vortech site puts that pulley impeller speed at 51157.89, if I go to 8K it puts it at 56K, what actually happens I am not sure.
AA Preferred Dealer
AA Preferred Dealer
