Results 1 to 5 of 5
Thread: Drilling holes for lap belt mounting
    New England
    E36 M, E32 740i/6, 997 S
    I am installing 6 point harnesses in my M and the only thing I have left to do is drill holes in the transmission tunnel to mount the inner lap belts. The problem I'm having is I'm not quite sure where to drill the hole. I'm working by myself and it's hard to get your bearings going from inside the car to underneath and vice versa.
    I would like to place the hole directly across from the OE seatbelt mounting hole on the outer side, but when I go under the car it almost looks like the carrier for the center support bearing is right there. I'm also concerned that there won't be a large enough surface to get the whole backing plate flat against the sheet metal without placing the mount significantly higher up the tunnel than the OE mount is on the other side.
    Does anyone have any photos of where their mount sits on the inside of the car and what that looks like underneath?
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    Special epoxies are sold to do the job you are talking about - fill the space between two parts. One is called Chockfast Orange.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Drill a small pilot hole from the inside or use a punch to indent where you want to go
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    I have eyelets welded in with reinforcing plates. Wasn't able to go underneath for a pic, but here's a view from inside. The mounts are located on the diagonal part of the transmission tunnel approximately 10" forward of the rear seat bulkhead. It looks slightly closer to the bulkhead in the photo due to the angle of the camera. The correct position for your mounts depends on where your seat is located.
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    Quote Originally Posted by cohny View Post
    My outboard lap mount is in the OE harness rail bolt hole, the inboard on the tunnel a bit over an inch farther back, pretty much exactly lined up with the back edge of the center console. I forget the details, but that turned out to be the location allowing the backing plate to fit under the tunnel while providing good geometry for the lap harness. And yes, it was tricky to figure out the right location. I tacked the backing plate under the tunnel so that I could insert the bolt from inside the car while working alone.
    I also chose to use the Brey-Krause harness brackets (http://www.bkauto.com/R_9201_Harness...e_p/r-9201.htm), which provide a nice swivel (parts for which aren't shown in their picture) and get around the problem of properly clocking an eye-bolt. Expensive though.
    Neil
  1. Mounting a Harness Lap Belt
    By Tommy R in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-03-2004, 03:34 PM
  2. Replies: 17
    Last Post: 05-31-2003, 01:22 PM
  3. sideskirt drilling templates
    By JedzE36/5 in forum 1991 - 1999 (E36)
    Last Post: 05-12-2003, 01:26 AM
  4. Mounting bar for belt harness
    By bimmermeupscotti in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-18-2002, 09:54 AM
  5. Replies: 0
    Last Post: 03-16-2001, 02:01 AM
