Just took these off of the car. They are Broadway Static 500S coilovers with 16K/18K spring rates. Fronts have about 30k miles on them and rears have about 10k miles. I haven’t cleaned them up but it’s obvious, there’s quite a bit of rust/corrosion on the fronts. Everything functions fine (in terms of ride) however height adjustments might get tricky due to the corrosion and the collars are pretty chewed up. The rears are still in pretty good condition which is a given since they haven't been on the car as long.
I replaced them with ground control coilovers because the rears wouldn’t go high enough for track use; the highest the rears went was maybe a half inch above the lip of the rear wheels. Fronts can be raised to stock height. They do go low as fuck though if that’s what you are into. Broadway static is a pretty nice company to work with and have all of the parts available if you want to refresh/rebuild these.
Looking to get about $500 plus shipping but I am more than willing to negotiate.
Pics can be found here:
https://imgur.com/a/HxcaiHc
