Results 1 to 14 of 14
Thread: Some Dash Lights are constantly on...
    May 2018
    wilmington, NC
    bmw 325ci
    2005 325ci
    I went on vacation came back after a month my battery was dead. I jumped the battery and ever since then some dash lights have been stuck on. the windshield washer light, the brake light, DSC, and tire pressure .
    These are the only ones that are constantly on after jumping the car. they are lit up orange, i noticed when i put the emergency brake on the light turns red.
    I tried to reset it by watching some videos on youtube by disconnectiing the battery but it didnt work.
    Does someone know how to fix this? Im thinking it's perhaps a relay? or could it be voltage regulator and the battery like someone else had said?
    I've tried searching the forums and google for the issue that i'm sure someone has had before but no luck!!
    Any help would be appreciated , Thnx!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Did you replace the battery? Google “BMW E46 hidden OBC functions.” Test #9 will show you the voltage as seen by the engine computer (DME in BMWspeak). Check and report back the voltage when the:
    - ignition is in the “on” position with the engine off
    - engine idling
    - engine revving at 2000rpm.
    Theres no relay that’d cause this issue.
    May 2018
    wilmington, NC
    bmw 325ci
    No, I didn't change the battery. The car drove fine after I got it started, just those lights came on. Ok I'll do the test, and update the post. Thx
    May 2018
    wilmington, NC
    bmw 325ci
    Quote Originally Posted by MarcoZandrini View Post
    - engine idling
    Ok did the test here are the results
    13.8 on position engine off
    13.8-14, engine idling
    14.1 engine revved
    13.2-13.8 with air condition on
    Hope this helps to figure out what's going on...
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    http://forum.e46fanatics.com/showthr...topics/1093250
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Apr 2015
    Netherlands
    2000 E46 328i
    Quote Originally Posted by Osouls View Post
    14.1 engine revved
    So is your battery charged and OK now, or do you still need to jumpstart the car every time?
    13,8V is quite high if the engine is not running..
    Yellow lights mean error, so scan the car with INPA or have someone do it for you and see what's wrong. It might just need to be cleared and then everything is fine..
    May 2018
    wilmington, NC
    bmw 325ci
    The car runs and starts fine , haven't had to jump it since then.
    Ok maybe I should buy a inpa, any suggestions.
    I found one on Amazon with good reviews.
    BMW INPA K+DCAN Interface Diagnostic OBD II Cable Work with ISTA SSS NCS Coding Winkfp Programing Support E serials(with Switch) Support E39 E46
    Apr 2015
    Netherlands
    2000 E46 328i
    I have good experiences with these guys: https://www.cable-shack.co.uk/
    May 2018
    wilmington, NC
    bmw 325ci
    OK sooooooooooooo I finally had time to load INPA onto my lappy and go through the diagnostics scan....which there were some errors in there that i did not copy down i probably should have but in any case i cleared all the errors and still the yellow lights are on ....anyone have any other ideas? I was reading another post and perhaps i need to drive it so the lights can reset..i have not driven it as of yet.
    Apr 2015
    Netherlands
    2000 E46 328i
    If the lights are still on, just hook up your laptop again and scan the errors again?..
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Google “BMW E46 hidden OBC functions.” Test #2 tears the gauge cluster. Any issues with the cluster will be obvious.
    May 2018
    wilmington, NC
    bmw 325ci
    Thumbs up
    I just wanted to drop a line to everyone that helped with this problem....I finally figured everything out.
    TY Raddee for the INPA idea...it worked!!
    1. the windshield wiper light was on because it had no windshield wiper fluid in it haha...stupid me
    2. the dsc light was because it had an error code- INPA cleared it
    3.ABS light was error code- INPA cleared
    4.TPS light on for some reason the ECU lost the configuration of the sensors. Reset using INPA.
    Instead of being just one problem it was 4 problems.I had to clear the error codes by using the INPA in the 3 different sections.
    TY everyone who helped! I really appreciate it!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Good to know! Glad you got it straightened out.
    Apr 2015
    Netherlands
    2000 E46 328i
    You are welcome and congrats on passing your INPA exam
  1. E36 318 dash lights and tail lights stay on
    By Tdailey27 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-13-2018, 03:25 AM
  2. Is CD player or the temp dash lights dimmer then the other dash lights ?
    By Yasir in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-12-2004, 08:31 AM
  3. 95 740 iL dash lights are out
    By ataie in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-05-2004, 04:53 PM
  4. all dash lights off
    By ataie in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-05-2004, 05:16 AM
  5. Brake lights constantly on!!
    By Uzy7686 in forum 1991 - 1999 (E36)
    Last Post: 02-13-2004, 08:26 PM
