so i had a issue with the factory calipers, so i just opted and bought a bbk for the e30. after installing it and bleeding the brakes, once i start the car i have no pedal pressure...possible bad master cylinder, brake booster??? pleasee help!!!!!!!!!!! or try bleeding the brakes again im at a loss?!?
86 Bronzit 318i m10b18 coupe (EuroSpec), GC coilovers, DOEC 40 Carb, Wilood BBK
usually, a bad booster makes the pedal hard.
No e30s again.
How big are the new calipers and rear cylinders compared to stock? Your car probably has the 20mm master cylinder which could be overwhelmed by larger cylinders at all four corners. You may need a larger master to bring things back into range. You may still have air in the system as well.
Interested in vintage cars? Ever thought about racing one?
Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!
apparently i didnt get as good of a bleed as i had thought, went and got a vacuum pump and bleed them that way and they work just fine now thanks guys!
great!
No e30s again.
