Results 1 to 25 of 25
Thread: CAS crash whilw programming
    May 2018
    tremblant, quebec, canada
    x3
    hi everyone
    i have to update dme on e84 because of a dtc. with j2534 cardaq plus 2 passtru adapter and ista/p directly from bmw website. because of a ppt adapter ista/p won't let me reflashing only one module i have to update all. when i'm reprogramming CAS i receive a overvolt message on ista/p (voltage over 15v) and a fail!!! after this ista was unable to reconnect to the car. now all the car was dead nothing is working without maybe parking lights.. i have ordered inpa k+dcan interface and try to reflash cas with winkfp and after the bar was at 100% i got error with code 2086 signature check failed. if i check programmation with inpa i have status 12 for cas and 255 for jbe. now part number on cas is weird yyy***** and vin is like WAAA00000000 or something!!! at this point i don't know what to do without buying a 1500$ cas module.
    any help will greatly appreciated
    thank you
    Jul 2004
    Houston, TX
    36 Cylinders
    You don't have to buy any module. This happens. Especially with improper chargers. Especially those horrible shop things on wheels.
    It's recoverable, but keep in mind that a K+DCAN has the capacity of making some modules worse.
    Flash JBE first, then flash cas (with key out) and every other module that is out.
    Then code whole car.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jul 2004
    Houston, TX
    36 Cylinders
    To be fair, a new CAS is only around $350, but it wouldn't solve your problem.
    I think a K+DCAN should be fine for all of E84 modules, though.
    (I bricked my first module with a K+DCAN.)
    -Abel
    May 2018
    x3
    I haven’t try to flash jbe. do you think it’s why I always got that error? I don’t want to brick jbe to!
    Jul 2004
    Houston, TX
    36 Cylinders
    The jbe is already bricked.
    It will need to be recovered first before you even try to reach anything else.
    It recovers fine though.
    -Abel
    May 2018
    x3
    Do I need to turn uif on an update vin or it’s not necessary?
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, UIF should be on, just in case.
    Usually you can use the update flash function for this recovery. Winkfp will retrieve previous ZUSB just fine and do the lookup to get the new ZUSB by itself.
    -Abel
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    send me cas, car will start simple as that
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    Quote Originally Posted by Driiven View Post
    I have been trying to contact you. You have another PM.
    May 2018
    x3
    I have reprogram jbe and now is programming states is 1 !! But still same error while programming CAS Signatures check failed and still in programming states 12
    Jul 2004
    Houston, TX
    36 Cylinders
    What interface are you using currently? What program?
    -Abel
    May 2018
    x3
    K +dcan INPA câble and winkfp
    I update zusb in confort mode and everything went well the bar goes to 100% and after I get error
    Jul 2004
    Houston, TX
    36 Cylinders
    Sounds like the k+dcan failure that I was afraid of above.
    You should try to use the J2534 with winkfp. This means configuring ediabas as std:passthrud.
    Fixed
    -Abel
    Philadelphia, PA
    2005 M3 & 2004 330i
    You should try to use the J2534 with winkfp. This means configuring ediabas as std:passthru.
    To expand on this, I think this is what I would do:
    Go to C:\Program Files (x86)\BMW AG\PassThruD and copy these files to C:\Ediabas\bin
    Then go to C:\ProgramData\BMW AG\PassThruD and copy "PassThruD.ini" to C:\Ediabas\bin
    Then go to C:\Ediabas\bin, open Ediabas.ini, and change "interface = STD:OBD" to "interface = STD:passthrud"
    See if it works from there. This is assuming you've been using the same computer with the D-CAN cable and the J2534 interface
    May 2018
    x3
    My ista/p is on another computer but I can install bmw passthrud an copy other files! Since my jbe is working maybe i can buy techinfo subscriptions try to reflash CAS with ista/p j-2534???
    May 2018
    x3
    Dosen’t seems to work with J2534
    Error 300
    First hw interface could not be initialized!
    Ifh-0018 initialisation error
    May 2018
    x3
    I have retry with ista/p and it ask me to switch ignition off but key is not on switch. And after I receive a fault (the voltage at terminal 15 could not be determined)
    Can I switch terminal 15 with CAS that is not working!
    Philadelphia, PA
    2005 M3 & 2004 330i
    That makes me wonder if the J2534 stuff can actually detect ignition status. BMW does it a little weirdly on D-CAN cars.
    May 2018
    x3
    Since the CAS is not working the terminal 15 and 30 are on on both tools INPA with k dcan and ista/ p on another computer! And key is not on the key fob
    Jul 2004
    Houston, TX
    36 Cylinders
    If you are using K+Dcan with ista/p on another computer, I assume you using the emulator? The non-paid 'standalone' ista/p isn't built to run with K+dcan, so you have to use the emulator settings to emulate ignition on and off.
    Unfortunately all of this would be easier if you have an ICOM you can borrow?
    You seem to have good knowledge and friends around, so maybe someone has an ICOM?
    -Abel
    May 2018
    x3
    Sorry I’m not clear! I’m French person and I do the best I can to write English!! But it’s kind of worst! Ok back to real things!!! I have one computer with winkfp and k +dcan and another one with ista/p that I run on bmw website and I have to pay for. Ista is set to ptt Interface and i use J2534 cardaq plus 2 . Both software on both computer give me terminal 15 with voltage without key on fob.
    I have find a person that have ICOM. We should test it today.
    Jul 2004
    Houston, TX
    36 Cylinders
    Your English is perfectly fine. Probably better than my 5 years of French from school.
    I understood it as you were using the pirated ISTA-P with K+DCAN on emulator.
    Let us know how it turns out!
    -Abel
    May 2018
    x3
    Thank you!!
    Ok we have try with ICOM and it’s not working! After we have removed CAS, open it and the guy have weld wire directly on it to extract data! And he told me the eprom data is corrupted!! How this is happened! I have reflash it with web based legal version of ista/p and now the guy have to try to unbrick the eprom! Is this can be only caused by my battery charger that is rising voltage around 15v while programming?
    May 2010
    Memphis, TN
    2000 BMW 528i
    Hello, I have the same issue on 2008 E60. I try to update the DME as per customer request. I'm using ISTA P on line and CARDAQ-M J2534. CARDAQ-M is like CARDAQ-Plus and is listed by OEM BMW ISTA website as supported device. The ISTA automatically selects CAS when programming DME and there is no way around it. It started programming CAS and halfway trough it stopped. No communication with CAS anymore. No key being recognized and no key on. Car completely dead. So, it looks like I'll need new CAS or is there a way around it ???
    I'd like to add I've done the same job with the same tools on other cars and had no issues.
    Please let me know!
    THANK YOU!
    May 2010
    Memphis, TN
    2000 BMW 528i
    Problem solved, I found a company that can restore these modules. Just got it back, put it in and everything is back to normal. Couldn't be happier. Here is the link if someone needs this in the future https://www.precisionecu.com/collect...e-plug-n-drive
  1. Replies: 76
    Last Post: 06-14-2018, 02:58 PM
