Results 1 to 17 of 17
Thread: 2.8 coupe, and maybe 3.0 and M coupe too...pic needed
    Mar 2003
    somers,ny
    I would like a good pic of rear interior hatch floor area w/ carpet floor removed , so I can replace/position all the "tools and stuff" properly that reside there. I removed them all about yr ago to do related work, and never put them all back.
    I have a 2.8 coupe.....but perhaps a 3.0 ,and M coupe are all the same back there
    big thnx
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    http://www.waycoolinc.com/z3/essenti...irechange.html
    A Roadster, but probably enough to get you started.
    I'll snap a pic of mine on the way out of work tonight (also a 2.8 Coupe). Then I can see if I'm missing anything.
    Nathan in Denver
    Mar 2003
    somers,ny
    thnx Nathan!....
    ...but I really need a good pic of yours! I cant figure out just a few things.
    Aug 2015
    Denver, CO
    Quote Originally Posted by jrkoupe View Post
    thnx Nathan!....
    ...unless I'm missing something too.
    Nathan in Denver
    Mar 2004
    Blue Ridge Mountains, NC
    1999 Z3 Coupe
    If you still need one tomorrow am,I'll take a pic and post it.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Mar 2003
    somers,ny
    d........cool
    Mar 2004
    1999 Z3 Coupe
    d........cool
    Nothing is too much for another original coupe owner. Here you go. If you need more, let me know.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Mar 2003
    somers,ny
    D
    that could not be more perfect...big thnx!!!
    some interesting side notes: 1)my metal battery hold down "strap" is unfinished raw metal, did you paint yours black?
    2) my car had an impossible to reach/access short bolt that secured the "clip" holding the rear end side of battery down onto floor , while your pic shows an ez to reach loooooong bolt.....
    3)ok, its clear to me the 2 sockets in our tool tray are long gone from my life, wonder wa happened to those.....strange. What size are they?....wonder the significance of those 2?
    thnx fellas!
    Mar 2004
    1999 Z3 Coupe
    D
    some interesting side notes: 1)my metal battery hold down "strap" is unfinished raw metal, did you paint yours black? No that's original
    2) my car had an impossible to reach/access short bolt that secured the "clip" holding the rear end side of battery down onto floor , while your pic shows an ez to reach loooooong bolt..... Its just the pic, There's a short bolt - not easy to reach.
    3)ok, its clear to me the 2 sockets in our tool tray are long gone from my life, wonder wa happened to those.....strange. What size are they?....wonder the significance of those 2? One is original 10mm with a thru hole for a rod. The other is mine - I'd always wondered where that had disappeared to.
    thnx fellas!
    Just discovered that my rear wiper and defroster don't work. I guess I'm dissecting the wire bundle at the hatch this weekend. Something to do while it rains.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Aug 2015
    Denver, CO
    Quote Originally Posted by daven View Post
    When you pop the boot out of the hatch, pull some wire from the car side (there is a few inches of slack). I shot a little bit of lube in the boot so I could slide the boot as far left as possible. After that, it's pretty easy, depending on how many wires are broken. I had a grand total of ONE broken, but two were missing some insulation. I hit those two with solder and wrapped them tight with E-tape. I then added about a 1/2 of wire to the broken one with a stout solder joint on each end. wrapped that again in E-tape, then wrapped the entire bundle and reinstalled the boot. I maybe spent 15 minutes total.
    Nice! This tells me I'm missing a piece or two from mine. I'll find them due to my OCD, but I'll never use. Hmm, looks like my corroded lug wrench could use a replacement too. It must have been left outside at some point in its life, because nowhere else on the car has any rot like that.
    Attachment 629787Attachment 629789Attachment 629790
    Hmm, BMW doesn't even list the two sockets...
    http://www.realoem.com/bmw/enUS/show...diagId=71_0200
    Nathan in Denver
    Mar 2003
    somers,ny
    D
    wait a sec,
    that is clearly a loooong bolt (on neg terminal side of batt) no?......it is securing the little metal "clip" that secures that end of the batt to floor......I have a tiny short bolt that Im now not even using after the new batt install of a few days ago.....its secure enuff.
    good luck on the repair!!!!!
    Aug 2015
    Denver, CO
    D
    Don't get jealous of length. I have short one (bolt!) too. I recall it being a bit of a pain to install. I think I taped the bolt to my socket so I didn't keep dropping it in the abyss.
    Nathan in Denver
    Mar 2004
    1999 Z3 Coupe
    How right you are. long bolt on the neg end, short bolt on the inside of the black metal strap. Replacement battery is a little shorter height, that's why the paper shim under the strap.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Mar 2003
    somers,ny
    jealous of length.....funny
    right now I guess Im good w/o using that lil bracket,....... the new batt is snug
    Sams Club really rocked on this purchase
    oh, r u guys venting your battery? edit: D I see u r, at the pos end
    M trunks are different than non-M's for the record
    Not all cars came with all the tools and everything. Nor did they come with the long bolts for the lower screw-down plate. Mine is a short bolt as well.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    My 3.0 has both. Long bolt for the shoe, short Allen bolt for the strap.
    Mar 2003
    somers,ny
    buying a long bolt is a qwik and cheap fix to reduce the short bolt stress......lol
    my strap had a short allen
  1. Considering M coupe purchase and others --> advice needed
    By yoyo99 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-27-2004, 01:03 PM
  2. M coupe parts needed- Atlanta salvage?
    By zrchris in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-29-2003, 02:48 PM
  3. Psychiatric Help Needed - Selling 2000 M Coupe
    By Reliv in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-08-2003, 06:07 PM
  4. M Coupe Stereo Wiring Help Needed Please!
    By PDX M Coupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-26-2003, 10:05 AM
  5. Dyno Tips for S54 M Coupe Needed...
    By Mthusiast in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-29-2003, 01:40 AM
