Page 1 of 9 123456789 LastLast
Results 1 to 25 of 220
Thread: MotorMouth93's 2003 540i/6 Quasi-Restoration Build Thread
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    Edit: I cleaned this thread out but am slowly putting it back.
    Hey guys! I'm brand new to the forum and new to BMWs but I've been around cars for a while now. Before buying the 540 I had a 1999 Integra and a 1994 NSX, but the Integra was totaled when an SUV rear-ended me at a stoplight and pushed me into the car in front. Since the Integra died and I don't want to daily the NSX, I started looking for a suitable replacement. I was looking for something quiet, comfortable, enough room to be practical, manual, fun to drive, and around the 10k price point. From my research I'm expecting to spend a good deal more maintaining this car than I have with my Hondas, but I'm not too worried since I do all my own work and 540 parts are pretty cheap.
    More info about my previous cars and the work I've done on them can be found in these build threads: 1994 NSX, 1999 Integra
    Anyways, about the car, 2003 540i MSport, 6-speed manual, ~93,000 miles, sapphire metallic black, black interior. The exterior of the car is in great shape, I know a few panels have been repainted but they match perfectly and the only real exterior flaws are minor door dings that will get taken care of during my PDR appointment on Monday. The interior is in good shape as well except for the pillars which are peeling, no rips or tears anywhere on the seats or other upholstery though.
    The previous owner also had a massive stack of service records, within the past couple years it's had a cooling system work, Dr. Vanos VANOS solenoids installed, valve cover gaskets, etc. done. The only real mechanical issue at this point is a slipping clutch, but I was able to get a decent discount because of it so I'm happy.
    First few photos, I'll be posting a lot more as I start tearing into things.
    The car is not without it's faults though, I have a fairly long punch list of minor stuff to take care of along with minor modifications.
    • Replace clutch (ordered)
    • Replace shifter bushings (ordered)
    • E60 short shifter (ordered)
    • ZHP shift knob (ordered)
    • Replace transmission fluid (ordered)
    • Replace RMS (ordered)
    • Replace input shaft seal (ordered)
    • Replace output shaft seal (ordered)
    • Fix headlight adjusters (ordered)
    • Morimoto FX-R HID projector retrofit (already have)
    • Brand new Umnitza lenses since 2003 headlights have to be cut open (ordered)
    • Orion V2 angel eyes (ordered)
    • Touch up minor scrapes on the bottom of the bumper lip
    • Very slight PS leak at the hose
    • Very slight valve cover seep
    • Change oil/filter (picking up supplies at dealership)
    • Brake fluid flush/bleed
    • Replace passenger side rear window regulator (ordered)
    • Fix driver seat lumbar support
    • Disconnect seatbelt height adjuster cables, my girlfriend is tiny so the belt cuts into her neck.
    • Get new keys with functional keyless entry
    • Can't open the trunk with the key, need to inspect the linkage
    • Replace bluish interior LEDs with warmer LEDs
    • Install front and rear dash cameras, likely going to be Blackvue DR470.
    • Replace chipped badges (supplied by previous owner)
    • Replace front and rear windshield moldings (supplied by previous owner)
    • Paint correction (have equipment already)
    • CQuartz ceramic coating (already have)
    • MAYBE: PPF on front bumper, side skirts, fenders, hood. (already have a roll of film)
    • MAYBE: Rebuild + powdercoat brake calipers, I have blasting and powder coating equipment so I might get around to this at some point. Once you've had powdercoated calipers you can't go back, they are so much easier to keep looking nice. Brake dust just wipes off.
    • Electric exhaust cutout before the muffler, I like having a quiet car but I also want V8 noises. I have an aftermarket exhaust on the NSX and I love it, but sometimes it's annoying so I don't want to go that route here.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Welcome to the E39 forum.
    Don't forget to get a new pressure plate and throw out bearing. If you plan on using your old one it will need to be reset as it is a self adjusting pressure plate.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Nice car. Welcome to the fun of E39 ownership. In for updates.
    May 2018
    Austin, TX
    [deleted]
    JimLev's Avatar
    Sundance Mesa, NM
    Sounds good.
    Just to let you know if you decide remove the flywheel you'll need a special T60 bit. The flywheel has an alignment ring in one of the crank flange bolt holes to keep the flywheel aligned with the crank so the DME knows where it is when the engine is running.
    The ring can fall out when the flywheel is removed so make sure you note what position the flywheel is in when you remove it so it can go back on in the same position.
    If it's not put back on correctly the engine will either not start or just barely run.
    Lets see a pic of that NSX.
    May 2018
    Austin, TX
    Quote Originally Posted by philly98540 View Post
    Thanks!
    I bought the genuine BMW clutch kit from ECS tuning so it includes the friction disk, pressure plate, and throwout bearing, and I ordered a steel pivot pin, alignment tool, and CDV delete to go with it.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Psst, mods, I think you have to approve his first post. Can't see it as a normal user.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by computiNATEor View Post
    Nate, must be some forum software bug, I've approved it it 3 times now.
    Nice NSX MM93
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Nice NSX MM93
    Hmm. I've been experiencing some odd issues lately. Couldn't run searches, my iPad wouldn't connect for a few days...
    Anyways.
    Welcome, MM93!
    Nate J.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Welcome! You've got a real nice 540i/6 there, and you're definitely approaching it with the right attitude. Unfortunately a lot of Honda owners buy a BMW without thinking about the maintenance and then they complain about how unreliable BMW's are when something breaks.
    1995 525i 5-speed - Thread
    May 2018
    Austin, TX
    [deleted]
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by MotorMouth93 View Post
    Thanks for the warm welcome guys! Also are there any keys for these cars that don't have built in keyless entry buttons? I'd much rather just unlock the car manually as the 3-button keys are big and bulky.
    There is a smaller valet key:
    (Thanks, Qsilver7)
    Nate J.
    May 2018
    Austin, TX
    [deleted]
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    She looks awesome, very nice!
    Nice work on the headlights. Why the Morimoto Minis? I went with EvoX-R 2.0s as they're basically drop ins, and I used eBay "COB" LED angel eyes, which look nice, IMO.
    And your steering wheel re-wrap came out a million times better than mine
    Nate J.
    May 2018
    Austin, TX
    [deleted]
    Last edited by MotorMouth93; 02-14-2020 at 05:21 PM. Reason: My script blocker was doing something to screw up line breaks, but it's fixed now.
    Aug 2017
    Tampa Bay Area florida
    1998 528i
    Very clean work I'm jealous of how nice your interior is and your steering wheel wrap my wife did mine and it looks married great if you get my meaning.
    Where did you get your wrap.
    May 2018
    Austin, TX
    [deleted]
    Dec 2008
    Long Island
    528iT
    Welcome to the forum! Great looking car you have there.
    I did the D2S retrofit as well in my fiance's E46. Did take some trimming but they fit very well and the output is insane.
    Dec 2012
    Australia
    02 530i 05 156SW 05 166
    Man, top work on that steering wheel. Might have to have a go when my m wheel gets a bit more worn.
    It's interesting the specs the later 540s came with. Mostly m sport stuff minus the lip spoiler and plus the comfort seats.
    You know my 525i looks pretty much the same from behind hey? Looks like they use the same tip for the exhaust. : p
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    I changed the rear main seal as well, rather than change the whole seal plate,
    Yeah I think that's SOP. Replacing the plate is completely unnecc IMO... that never really leaks or has issues. Just do the main seal itself...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    May 2018
    Austin, TX
    [deleted]
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    You are the second person I have seen to have an NSX and then get an M-Sport 540i E39 IN BLACK & Manual in the past week!
    https://www.youtube.com/watch?v=YiiMehdmUA0 (Unless you're the same person as in the Youtube Channel LOL )
    E39 WhatsApp Chat Gruppe
    May 2018
    Austin, TX
    [deleted]
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Color banding is fun
    Nate J.
    May 2018
    Austin, TX
    [deleted]
  1. Build Thread: 1991 325ic Restoration + engine swap
    By E34DIYer in forum 1983 - 1991 (E30)
    Last Post: 09-28-2021, 06:50 PM
  2. Not Another First Turbo Build Thread
    By drstuess in forum Forced Induction
    Last Post: 04-07-2020, 11:34 PM
  3. Jeremy5000's Build Thread
    By jeremy5000 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-25-2018, 11:43 AM
  4. Replies: 350
    Last Post: 02-21-2018, 08:43 PM
  5. Trading in my 2002 9/01 build for a 2003
    By chubbyasian in forum 2001 - 2006 M3 (E46)
    Last Post: 12-04-2002, 03:45 PM
