Results 1 to 4 of 4
Thread: A/C problems
    May 2018
    St. Gabriel,La.
    2010 750i
    A/C problems
    Hoping you guys can help. Blower and compressor turns on on inatial start up beu then shuts off. works fine morning and at night but midday nothing from front blower. Just rear with warm air. compressor and front blower are off...any knowledge would be greatly appreciated. Thanks in Advance!!!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Maybe too low AC filling, check that. Pressure switch also switches off when there is too low pressure
    May 2018
    St. Gabriel,La.
    2010 750i
    Tried that...Same results
    May 2018
    St. Gabriel,La.
    2010 750i
    turned out that for some reason the compressor shuts off with front blower. after inspecting the blower i found that plastic was melted around both brushes. causing them to not make contact with rotor. freed up brushes motor worked fine. reinstelled just to see and everything worked fine. installed new motor and cab filters everythig ok..Thanks for the Help!!!!
  1. HID problems
    By xiskingmofo in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-08-2004, 07:04 PM
  2. 2 Problems
    By 1clean95'm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-25-2004, 11:01 AM
  3. All this time, problems problems....now I got a CEL
    By 95MMM in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-11-2003, 08:28 AM
  4. Mercedes 320E problems vs 96 328i problems?
    By yosshimura in forum 1991 - 1999 (E36)
    Last Post: 06-16-2002, 12:07 AM
  5. Problems Problems? Or Just Fake Problems?
    By black on black in forum 1999 - 2006 (E46)
    Last Post: 05-17-2001, 10:20 AM
