Results 1 to 3 of 3
Thread: Eibach Springs Question
    Sep 2002
    TX
    01 Z3 3.0i
    For a 3.0 coupe,Eibach shows their springs were tested on factory dampers, I called them and the tech confirmed this as being correct (for what that worth). I was under the understanding that if you were to use any type of lowering spring, h&r or eibach etc, That you really needed to replace the dampers for lowered spring even a slight lower. Thoughts on eibachs with stock struts.
    The biggest reason I ask is,Bilstein sports have been on back order since Nov of last year and have never been a koni person but may have to become one.
    Springfield, Ohio, USA
    1998 Z3 Roadster
    Here is a picture of my eibach springs compared to the originals, both of which are broken. I'm using Bilstein Sport shocks.
    Here is how Bilstein Sport shocks compare to Bilstein HD shocks.
    Mar 2003
    somers,ny
    billie sports traditionally are a bit shorter.
    Koni usually have a softer less jarring ride...i ran billies since the 70s....my track car has koni.......I prefer Koni overall.
    if the drop is minimal and rate is not overly zealous a stock shock "could" work...not optimal but could work...not my choice to!
    and some higher rate sprgs can be stock ride ht
  1. Koni SA /Eibach Springs/ Eibach Sways Reveiw
    By tlp-96M3/2 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-21-2005, 03:57 PM
  2. are eibach springs softer than stock m3 springs?
    By hc1001 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-10-2003, 02:37 AM
  3. Eibach or H&R' springs to go with Konis/Eibach sways?
    By robstahl in forum 1992 - 1999 M3 (E36)
    Last Post: 06-04-2002, 01:50 PM
  4. Eibach springs question
    By Cock318 in forum 1991 - 1999 (E36)
    Last Post: 01-17-2002, 10:08 AM
  5. Eibach Pro springs vs. 328i sport package springs
    By ~vo328~ in forum 1991 - 1999 (E36)
    Last Post: 03-15-2001, 03:55 AM
