Results 1 to 4 of 4
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    E70 LCI Inner Tail Light Failure / LED Driver Replacement
    My inner tail light (the ones mounted to the tailgate) on the passenger side has failed. They are LED and I believe they are on all of the E70 LCI models. My X5 is a June 2013 build date. I see that the F25 X3's have LED repair kits out there for the taillights to replace the faulty Valeo board. Has anybody tried this fix on the X5 inner tail lights? I would like to do this vs. buying a new inner tail light at nearly $200.
    Here are links to the X3's fixes. My guess is that it would work on the X5 LCI models but I am not sure. Apparently re soldering failed joints is only a temporary fix.
    https://www.ledsupply.com/blog/common-bmw-led-tail-light-fix/
    Replacement Board for sale on eBay.
    https://www.ebay.com/itm/For-BMW-X3-...8fe2%7Ciid%3A1
    Apr 2016
    MTL
    E90 / E70
    Any update on this one?
    Did the X3 fix work?
    THX
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    Haven't dug into it yet. The seller of one of the circuit board solutions on eBay is curious as well. I am surprised this is not more common on the e70 LCI X5's. When I find the solution I will post with details.
    Oct 2016
    Upstate NY
    2001 BMW 740i Sport
    Update.. LED board appears to be fine. The gaskets failed and water / salt mix got behind the taillight causing corrosion and shorted out the light bulb housing.
  1. Tail light failure
    By zeit00 in forum 1991 - 1999 (E36)
    Last Post: 04-24-2004, 12:15 AM
  2. Tail light failure... please read
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-26-2002, 07:58 PM
  3. Tail light failure issue....
    By R.Stunna in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-30-2002, 11:06 AM
  4. Help! Right side lights doesnt come on. "TAIL LIGHT FAILURE"
    By KingTiger in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-26-2002, 09:08 PM
  5. low beam + tail light failure on OBC
    By Changster in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2001, 01:12 AM
