Results 1 to 5 of 5
Thread: Sloppy clutch pedal parts to buy?
    May 2017
    Mb, Canada
    1998 BMW 328ic
    OK, my 1998 328ic has a sloppy clutch pedal. I did install a cheater spacer bolt on the floorboard to make it shift nicer (why BMW does not have a adjustable slave rod is beyond me) but the pedal can twist to the side thus hitting and jamming on my bolt. The bolt is wide (1-1/2" dia) and has a rubber tip so I'm guessing its all in the slop in the pedal.
    So what do I replace?
    I have ordered a set of bronze oilite bushings do I also replace the
    pedal?
    Not sure what else while I'm down there.
    Thanks,
    Don B
    Oct 2003
    Seattle
    99 M3
    With the proper bushing (that you ordered) the pedal looseness should be corrected, but you will have to inspect your pedal for wear/damage when you replace the bushings.
    Conversely, there is a steel clutch pedal that Mason Engineering produces.
    Jan 2018
    Bay Area, CA, USA
    1998 BMW 323IC
    I installed delrin clutch pedal bushings which cured most of my side to side slop. But as mentioned, the stock pedal itself is made of plastic and might need replacing along with the bushing if it is worn from being slanted.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    You're gonna want Item 4,
    http://www.realoem.com/bmw/enUS/show...diagId=35_0454
    It's somewhat of a bitch to put the clutch pedal in, there's certainly a trick to doing it. It helps to take the seat out so you can lay on the floor.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    It should just be the bushings as the plastic pedal should not wear. You also should already have the better designed tension spring return instead of the stupid M3 compression spring slide (that also love to squeak).
  1. Car stalls after clutch pedal is raised after clutch install
    By meinyourM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-24-2004, 07:23 PM
  2. "Creeky" clutch pedal and gas pedal???
    By hyperknight in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-19-2003, 02:23 AM
  3. HELP! Clutch pedal will not disengage clutch
    By GPappas in forum 1991 - 1999 (E36)
    Last Post: 02-11-2003, 05:15 PM
  4. Squeeky Clutch Pedal = New Clutch??
    By JasonJ75 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-08-2001, 06:45 PM
