Results 1 to 12 of 12
Thread: Instrument Cluster OBC
    May 2018
    Raleigh, NC
    2001 BMW 325i
    Hi,
    I have an 01 325i with an instrument cluster that is starting to go bad. Occasionally the screen flickers, and the clock adjuster does not work anymore (typical problem). Anyways, I am debating on getting a new instrument cluster. My turn signal stalk does not have the "BC" button to switch the clock to other things like mpg and range, but my question is, if I buy an instrument cluster that does have those functions, can I replace my turn signal stalk with one that has BC button and make them compatible? My goal would be to add the feature of the scrolling through the functions using the BC button if possible. If not, I guess I could just get the same model cluster (boring). Either way with whatever cluster I get, I'm going to have the mileage programmed to match my current mileage. Does anyone know where a good place to do that is? I found a service on eBay that can do it for $70.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    All the clusters had the "BC" function, you will need to just turn it on using PROGMAN or similar. You will just need the new stalk and know somebody that can program the car. I don't know the ebay guy, so I cannot help on that. My go to guy is Able, his handle is 328 Power 04
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2018
    Raleigh, NC
    2001 BMW 325i
    Thank you for your response. I am not familiar with how to use PROGMAN or how to get access to it. So to suit what I am looking for, I would need to install the new stalk and gauge cluster, then get someone to program the cluster for the mileage and to work with the stalk? I'm trying to figure out what order I should go through the procedure.
    If I went to a junkyard and pulled a matching cluster and stalk that has the BC button, would they automatically work together in my car? Then I'd just have to get someone to program the mileage?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The mileage has to be programmed or else you’ll get the “tamper dot” in the readout. The mileage is stored in the lighting control module (LKM). Find a shop that specializes in bimmers at www.bimrs.org. The shop should have the software to load the mileage (so you don’t get the tamper dot) and set up the “BC” stalk function.
    dworthy's Avatar
    Nov 2010
    PROGMAN is a suite of BMW tools, and if you don't plan on doing much in the way of changing much on the car, it would be better to just have a shop do it after you get the stalk in. If you have an older laptop with a serial port, you can get it to work. It takes some time to learn how to use it.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2018
    Raleigh, NC
    2001 BMW 325i
    Thanks! I found a shop in Greensboro, NC that said they could mirror the information stored in the chip from my gauge cluster directly over to a used one of the same part number, that way I don’t get the tamper dot and my car will think it is the original cluster. I’m hoping that works! Then after I get that settled I can install a stalk with the BC button and get a shop to activate/program that. Just in case for some reason my car rejects the used cluster after it has been programmed and the tamper dot comes on, will I be able to get the tamper dot off again but re installing my factory cluster?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The tamper dot results from
    a mismatch in the mileage numbers between the that in the LKM and that in the cluster.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by MarcoZandrini View Post
    Technically it results from a mismatch of the VIN, not mileage.
    Anyway OP:
    Don't bother with progman, it's an old, slow, and a bloated piece of software. Look up NCS Expert (head to the diagnostic software section of this forum and read - you'll figure it out in time).
    Fixing the mileage is a little bit tougher of a call. You'll need to reprogram the chip directly.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Good to know! So if you correct the VIN mismatch does the cluster “adopt” the mileage from the LKM?
    Philadelphia, PA
    2005 M3 & 2004 330i
    Unfortunately it only "adopts" the mileage if the cluster mileage is set to 0. If the VIN matches, tamper dot won't show, but it'll count the the mileage from whatever the cluster is currently set to.
    May 2018
    Raleigh, NC
    2001 BMW 325i
    Is the tamper dot permanent once it is activated or will it go away once the vin matches again?
    dworthy's Avatar
    Nov 2010
    Once everything matches up, the dot will go away, so no worries on that.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E36 Instrument Cluster
    By M3318 in forum BMW Parts For Sale
    Last Post: 03-29-2004, 01:26 PM
  2. WTB - Instrument Cluster
    By Low Level in forum BMW Parts Wanted
    Last Post: 05-19-2003, 05:55 PM
  3. WTB: Instrument cluster
    By mp318is in forum BMW Parts Wanted
    Last Post: 02-21-2003, 07:04 PM
  4. FS/FT: E36 325 Instrument Cluster
    By GQ_Style in forum BMW Parts For Sale
    Last Post: 12-12-2002, 11:49 AM
  5. WTB: 95 M3 instrument cluster
    By M3RCR in forum BMW Parts Wanted
    Last Post: 08-19-2002, 07:05 PM
