It's a 98 740i that the last few times i drove it drove just fine with no issues. It then was parked and spent about 6 months in the back of my family's property. Now upon start up it smokes pretty bad and if reved a few times the smoke begins to billow out of the exhaust pipes. It also has a rough idle but no check engine light probably due to the battery being disconnected for months. The smoke is thick enough upon reving to create a smoke screen fit for a hollywood production, so I am shying away from thinking it's the osv again. I changed the osv about 10,000 miles ago but the car has also sat around off and on since i did that about 8 years ago.
Thank you for reading and also for any possible solutions you may offer.
If it was outside it may just be moisture in the exhaust system. My E32 did the same prior to restoring it when it sat for quite some time outside. Does it smell sweet or anything? White smoke is usually headgasket failure but if the car sat, my money is on just moisture in the exhaust.
Have a look at the oil and coolant and make sure they are what they are supposed to be, and not chocolate milk
Sent from my ONEPLUS A3000 using Tapatalk
BMW 7er Website www.7er.com
1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
If it was either, the smoke would be blue and reek of burnt oil. Does it?
Some severe cases will cause a suction sound when you pull the dipstick out while the engine is running. Not always though. Give it a try. Have you let it idle for more than 10 min? If it sat for that long. Let it idle and monitor the Temps. See if the smoke goes away.
The smoke smells very heavily of exhaust and the oil looks good. At this point I am hoping it is water in the fuel system, the only thing is if that is the case I have no idea how long it will take for the exhaust to stop smoking.
It smells like exhaust and is white as can be
I would let it idle and drive it around the neighborhood if you can. If it was the osv or cyclone behind the timing chain it would be visibly blue and smell like burning oil. My E32 750 took maybe 20 min for the smoke to clear, and would come back for a few days on cold starts until it cleared. I would also get some fresh fuel in there too. Has the rough idle gone away?
I had white smoke with failed CCV, but I agree with the logic that it should have been blueish
I have let it run for over an hour today so far and it is still running currently. Still has a rough idle and is still leaking smoke like a smoke machine from the tail pipes. A very small amount of smoke is coming from the engine towards the firewall on the passenger side. Still no check engine light.
Check to see if the plugs are fouled up. Also when you look at the plugs, look to see if oil is pooling up in the plug wells.
I ended up running it for 2 hours straight and just from idling and a couple mins of reving i burned a 1/4 tank of gas. I feel like that is a horrible gas consumption rate.
Also I plan to check the plugs tomorrow when I have sun light again.
Plugs are fine. This time i managed to burn up a quarter of a tank in about an hour. Something is making it burn up an excessive amount of fuel while running very rich
That much smoke and fuel consumption could be a failed FPR - when the diaphragm gives up raw fuel gets straight into the manifold. So, check the vacuum pipe that runs from the PCV to the FPR for signs of fuel......
My BMW Repair YouTube Channel
Sounds like the PCV is bad or the seal to the manifold is bad. Mine had the exact symptoms you described and a new PCV with fresh silicone around the perimeter solved it 100%. I used an ebay special $40 knock-off part and I have no complaints so far.
$33 from Meyle: https://www.fcpeuro.com/products/bmw...-11617501563my
If the fuel consumption is that bad I'd advise against running it too much longer. You run the risk of washing off the oil film on the bore -> extraordinary amount of rejoicing . The 'new engine' kind.
You did, of course, check coolant level and coolant/oil colour, I assume.
Been working so much lately I finally just made time yesterday to spend some time with the car again. I also worked up the courage to take it for a quick drive even on bad tags, as a result the engine light turned on and I am now showing error codes P1585 P0308. If pcv and osv are the same thing as I currently believe them to be, I changed that part about 10,000 miles ago
Here you go:
https://www.meeknet.co.uk/e31/BMW_M6...entilation.htm
Sent from my SM-G935F using Tapatalk
After reading the info in the link, it was definitely the ccv that I changed. That was 10,000 miles and years ago, so i forget if there was a way to tell if the ccv has failed by just examining it after removing it. I would love to save the money if it is not the pcv again. I do remember having a blueish tint to the smoke right before i changed that part as it describes in the website linked by Timm, where as what I am currently dealing with is white as can be and I also believe it to be producing a much richer exhaust/fuel smell this time around.
Diagnostics is the easiest way:
https://www.meeknet.co.uk/E38/Diagnostics.htm
Was this resolved? Having the same issue after timing chain/guide replacement. It’s burning 1/8 of a tank just idling in the driveway while troubleshooting. No CEL. It’s driving me nuts. Replaced the fuel filter and regulator while waiting for a new one to show up tomorrow. Messed with every vacuum connection. Checked the regular vacuum line and it’s clear. Return line clear from the filter. It billows fuel.
Sorry to resurrect, but I was still having this issue. The car ended up breaking a connecting rod due to cylinder wash.
