Results 1 to 6 of 6
Thread: use copper anti-seize on Valve cover bolts?
    May 2018
    Chicago
    BMW 528xi, VW Passat 1.8
    Hello All,
    I am about to do my valve cover gaskets, was wondering if it is a good idea to use copper anti-seize compound on the valve cover bolts? I have heard that it helps but was curious if anyone here has had experience..
    Apr 2018
    Roma, IT
    2010 E61
    You shouldn't need to, but they need to be replaced (they're aluminum) and torqued to 9nm on the N52K.
    Oct 2003
    Seattle
    99 M3
    Wow!! I was surprised to confirm that the VC bolts are aluminum, one time use fasteners.
    I guessed that you drive a 530.
    http://www.realoem.com/bmw/enUS/show...diagId=11_3737
    I tend to use anti-seize on ALL my fasteners, either copper based or aluminum based, depending on application…even on my bicycles. LOL!!
    Apr 2018
    Roma, IT
    2010 E61
    His profile says 528xi
    They are also four different types of bolts.
    If your engine has a plastic valve cover, they are not aluminum and do not need replacing. If you have the metal valve cover, then they are aluminum and must be replaced and torqued properly.
    May 2018
    Chicago
    Quote Originally Posted by White94RX View Post
    Thanks for your feedback!. When I check the replacement valve cover bolts; the description says that those are aluminum however!
  1. torque specs for bolts on diff. cover
    By MarkE36 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-25-2004, 09:15 PM
  2. Replies: 1
    Last Post: 08-12-2003, 08:50 PM
  3. wtb: M50 blk engine cover/ valve-cover cover
    By v.b. in forum BMW Parts Wanted
    Last Post: 03-12-2003, 10:47 PM
  4. FS: 3.2L M3 valve cover for $50
    By dqm3 in forum BMW Parts For Sale
    Last Post: 02-10-2003, 10:30 PM
  5. torque and order for m42 valve cover bolts?
    By gotboost? in forum 1991 - 1999 (E36)
    Last Post: 10-09-2001, 05:36 AM
