Results 1 to 12 of 12
Thread: S52 tapping noise coming from block?
    Sep 2012
    Bimmer Cave
    1998 BMW M3 Convertible
    Hello everyone. I've been having some issues with the M3. The S52 has developed a nasty sounding tapping noise that seems to be coming from the block somewhere, and is very difficult to find with a stethoscope. Initially I thought this noise was coming from a couple failed hydraulic lifters, so I replaced all of them with new parts. I also replaced the upper and lower timing chain tensioners. After completed these repairs, and replacing several failed/failing lifters, I fired up the engine and the cursed noise still remains. I've stethoscoped the vanos unit, injectors, coil packs, all accessories, PCV, EGR, EVAP, and everything else that is accessible from the engine bay. The noise does not appear to be coming from any of these. Drained the oil and there were no signs of metal flakes or plastic chips from the timing system. I have no CEL codes present, and no other lights on the dash. The car idles with a purrrr. No loss in power is noticed. Here are two short videos I made yesterday. The sound you're looking for is the random tapping noise at idle. In the second video, the noise is consistent with revs when under load. Any help would be appreciated. I've all but decided to drop the engine cradle and remove the oil pan just to check it out. Has anyone on here heard this damn noise before?
    https://youtu.be/HTG84SWDIR0
    https://youtu.be/9mMKT5cM99A
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    My guess is rod knock / rod bearing. Sorry to be bearer of $$ news. I'm 75% positive, but let others chime in. I wouldn't be driving it anywhere IIWY. First video doesn't tell much, but the 2nd...ouch.
    I've heard it in Subarus.....like 25% of them...as the EJ257s love to starve rod bearings of oil.
    If I'm right, ensure you actually FIND what caused the oil starvation to the bearing as this might not be the last time you hear that noise. Oil pump, oil pickup, low oil, etc.
    Dec 2007
    l.a. california
    1997 328is
    What about pulley tensioners and or pulleys.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    Quote Originally Posted by ovation1000 View Post
    Very unlikely IMO. When they go, its a bearing with a constant high pitched, squeal noise (of the bearing spinning/grinding around a worn race). Nothing to cause the "tapping" ie impacting of 2 parts. Optimistic thinking, but it wouldn't be my first guess given the stethoscope difficulties of finding the location/source of it, and (most importantly) the 2nd video. Maybe if one of the bolts were loose, but again, it wouldn't be my first guess unless they were recently removed for some reason. I assuming the OP went over the entire engine via stethoscope shaft probe from the accessible areas looking for the source of the noise and couldn't find it. That eliminates almost all of the easy-to-fix sources of the noise.
    .....A spun or worn rod journal bearing that no longer fits it's cylindrical shaft on the other hand....Notice how the sound level increases when the engine is under load, then quiets down as he lets off.
    Rod knock sound videos to compare to.
    https://www.youtube.com/watch?v=Gz4myEP42ps
    https://www.youtube.com/watch?v=_0eu9zQiTig
    Aug 2015
    Bakersfield, CA
    1994 BMW 325i
    I would be shocked if it’s this simple but I had a similar noise not long ago and was certain it was my vanos, come to find out one of my spark plugs was just ever so slightly under torqued (I know I know rookie move) and there was a small compression leak making a knock noise. Tightened to spec and he noise went away. Also found a few horses again I’m sure...
    Dec 2007
    l.a. california
    1997 328is
    Just throwing it out there, you never know.
    Sep 2012
    Bimmer Cave
    Thanks for the input gents. I’ll have to remove the oil pan to see the condition of the bottom end. Hopefully I don’t find what I think it is...
    KC
    1995 M3 & 1998 M3 coupes
    I had a horrible noise I thought was rod knocking on my 95, but thankfully it was something else. I ended up purchasing a cheap engine stethoscope and traced it to the AC compressor. I removed the belt and the sound was completely gone. It ended up being the bearings were shot in the compressor. Just something to check.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by MikeUSMC View Post
    I wouldn't worry too much - you seem to have caught it in time, you're more than capable of doing this, it doesn't take THAT long to do, and it doesn't cost much either.
    Sep 2012
    Bimmer Cave
    Quote Originally Posted by E85STI View Post
    Quote Originally Posted by blckstrm View Post
    Thanks guys. After another close listening to this noise, it sounded like it was possibly coming from the block or flywheel. So I took off the oil pan (what a PITA that was) and examined the internals and the flywheel. I found no loose rod caps, no discoloration, no play from thrust bearings, no movement or anything about the flywheel, oil pump nut was secure... the only red flag I saw was some play on the oil pump chain...
    Jun 2010
    NY
    1997 328i
    Remove the oil pressure switch and put in a gauge. Also try running it without both belts (only for a very short time) try that on a fully cold engine and only for seconds.
    When you have the pan off, inspect that the oil pick up tube is not cracked.
    Wisconsin
    98 328IS 03 325xi
    Are all of your spark plugs right? I had a loose one and it made a knocking sound.
    Gave away my BMWs, driving a VW and an Audi now.
  1. Some noise coming from the suspension? Creaking noise from the 'axle pin'?
    By dcdomain in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-10-2006, 03:49 AM
  2. noise coming from the back
    By jhinck1414 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2004, 01:04 AM
  3. Bugging Tapping noise front inside the engine hood
    By archyx in forum 1991 - 1999 (E36)
    Last Post: 10-11-2003, 09:26 PM
  4. tapping/clicking noise
    By Wantacosmosm3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-26-2003, 10:47 AM
