Results 1 to 25 of 27
Thread: HVAC Unit
    birmingham,al
    2001 3.0 Z-3 RD'STER
    HVAC Unit
    Can this be repaired or do I need to replace the unit? See crack on the green section. It will not hold cable in place like the other sections.
    Sent from my SM-G920V using Tapatalk
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I'd try a careful application of epoxy first.
    birmingham,al
    Thanks Randy. I'll try that.
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    I hope you find an epoxy that works. I tried a few different substances when I was refurbishing my console and HVAC. No matter what I tried, when I inserted the cable, the clip cracked again. I ended up gluing the cable into the clip with GOOP, I think. Replacing the clip was a consideration since I had a spare control, but I didn't have tools to attach the barrel to the end of the cable had I cut the end off. Does a new cable come with the clip attached?
    I'm very interested in the solution of this problem.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
    Tallahassee
    1998 Z3 M Roadster.
    HVAC Unit
    There are good plastic epoxies
    Choose the right one.
    I would repair this. They are $100 + used.
    I always keep a spare on hand.
    birmingham,al
    Does this cable control the heater? I am asking because when I turn on the heater, and move the control knob to heat, it won't blow air onto my feet. However, it will blow air if I move control knob to defrost (front windshield) or onto my face.
    birmingham,al
    Would you believe $200
    Quote Originally Posted by magnetchief View Post
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Quote Originally Posted by MORRIE View Post
    Occasionally you find one with an entire console attached. And a clock. And 8 switches. And wood trim. And an e brake boot. I have too many consoles already, but not a terrible price for all those bits that you could sell to offset some cost.
    https://www.ebay.com/itm/BMW-Z3-Conv...8AAOSwPkBaYTui
    Nathan in Denver
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    Looking at the pictures that are included in the link Nathan sent, the green clip runs the cable to the heater, the black clip is the cable that controls the amount of heat, and the red clip holds the cable that goes to the defroster.
    Wayne
    1998 M Roadster
    Tallahassee
    1998 Z3 M Roadster.
    Lol. No.
    Whenever one pops up at my local pick & pull this is the first thing I remove.
    They charge me $23 for the ‘manual AC control’
    I usually flip them for $125 on eBay.
    Sell pretty quickly so I probably let someone have a good deal. But that’s ok. No need to be that greedy.
    Always keep a spare on hand for my own use if needed.
    birmingham,al
    Ok, the JB weld did not hold. I wished there was a way just to get just the green cable replaced. Something I don't understand...When I hold the broken plastic portion of the green cable with pliers, the cable that's attached to the firewall still does not move the metal cable back and forth when I turn the knob. However, it will move if I use my hand to move it. Is the metal cable secured inside the black covering so that it moves the green plastic connector? Can someone explain the process and why it's not properly working? (see pics)
    Tallahassee
    1998 Z3 M Roadster.
    JB Weld is not going to do anything.
    You need to bond the plastic back together.
    This is what I would use.
    https://www.amazon.com/Devcon-25ml-P...70_&dpSrc=srch
    birmingham,al
    I found a cable with with green plastic holder (the broken one on my unit...see section 1 on this thread). However, I am having difficulty determining how to remove the other end of the cable that's held by 2 metal rivits on the clear plastic clamp (see pic). The metal cable (inside the black tubing) is designed to be held in place so that it can slide back & forth inside the black tubing. So how am I going to remove the old cable held by the black tubing? I think that somehow the plastic clamp needs to be removed, but how?
    birmingham,al
    I managed to pull the cable from the little metal holder that's attached to the clear plastic piece held by the 2 rivets (see photo). Now, the question is can I get it back into the little metal holder so it will stay in place? I'm waiting on a replacement cable because the one I ordered (see photo) is cracked on opposite side of the original cable I am replacing. What rotten luck!
    Mar 2004
    Blue Ridge Mountains, NC
    1999 Z3 Coupe
    I've got a couple of ideas. But before I make a complete fool of myself, I need a picture of the other end of the cable and how it attaches to the lever and the "little metal holder".
    1999 2.8 Z3 Coupe
    Arctic Silver
    birmingham,al
    Thanks Daven for your interest. I have another photo posted where the problem exist (see post #14). The opposite end (see post #1) of the cable held by green plastic is cracked but I am awaiting a replacement cable that's not cracked.
    Mar 2004
    1999 Z3 Coupe
    Its the other end from the broken green plastic end, I'm interested in. How is the cable attached to the green lever? (to the left of the plastic clip) If you detach that end, the cable should (hopefully) just slide through the metal housing end sleeve on the riveted clamp. The new cable should come with metal ends attached to the cable that connect to the control arms on each end, the broken green clip and the black tubing - all as one assembly.
    1999 2.8 Z3 Coupe
    Arctic Silver
    birmingham,al
    Look at post #1
    Mar 2004
    1999 Z3 Coupe
    Ok I give up. I asked about the cable attachment to the lever shown in Post 13, Pic 1 & Post 14 Pic 2. If you detach that end of the cable from the green lever, it should slide through the metal sleeve on riveted plastic mount.
    1999 2.8 Z3 Coupe
    Arctic Silver
    birmingham,al
    Quote Originally Posted by daven View Post
    What that photo reflects is the new cable that is ready for installation into the green plastic lever (see photo #2 post 14). However the black tubing holding the metal cable inside must be inserted into the small metal sleeve that's attached to the clear plastic piece riveted onto the white plastic piece. That might be easier done than said. I had to pull on the cable vigorously to remove it from the metal sleeve. I think I am going to have some difficulty getting it back into the sleeve. However, it must be stationery inside the sleeve in order for the levers to properly work. Unfortunately I am still waiting on my contact to find and ship that particular cable.
    Mar 2004
    1999 Z3 Coupe
    The black tubing is actually called a housing. It should be metal lined vinyl. You can judiciously sand the vinyl to get it to fit into the cable stop (metal tube) But you are right it needs to fit snugly so not too much sanding. You might alos try a little rubbing alcohol as a lubricant, it will evaporate leaving the housing 'stuck' in the stop.
    I misunderstood your problem. I thought that you were trying to figure out how to take the cable out of the stop, not trying to get the housing back in.
    1999 2.8 Z3 Coupe
    Arctic Silver
    birmingham,al
    Thanks for the information
    birmingham,al
    So you guys know the answer to This? When I turn the knob from cold to hot why does it not turn freely but instead stop at a half way point but given a few minutes will turn all the way over? Will replacing this cable resolve the issue or does another cable need to be replaced?
    birmingham,al
    FYI...The metal clip attached to the plastic piece that holds the black housing can be removed from plastic piece so the black housing holding the metal cable can be removed and then reinserted so the cable will be in a fixed position allowing the controls on the unit to properly work....just used a pair of needle nose pliers to squeeze the metal clip and out it comes.
    May 2020
    Toronto, CA
    2003 Subaru Forester
    Thanks for your replies. To tell the truth, I don't understand this at all but I would like to. My uncle can help me to repair the console, but it's a shame for me to ask him every time when I need help. I even thought to study online and get an HVAC license while we stay home in quarantine. I found some interesting offers on https://www.hvacschools411.com/hvac-certification-license-online/ that I could handle because I have a lot of free time now. Does anybody know anything about them?
  1. Problem with HVAC control unit
    By JonB in forum 1992 - 1999 M3 (E36)
    Last Post: 03-24-2004, 04:26 PM
  2. Replacing HVAC blower unit
    By hccyong in forum 1992 - 1999 M3 (E36)
    Last Post: 01-10-2004, 12:07 AM
  3. light sensor on stock head unit and head unit wiring diagram
    By mndcrm1 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-02-2003, 07:31 PM
  4. WTB: 92-95 HVAC (A/C) Unit
    By TheBestCow in forum BMW Parts Wanted
    Last Post: 02-15-2003, 10:12 PM
  5. Replies: 2
    Last Post: 02-25-2002, 12:39 AM
