Results 1 to 7 of 7
Thread: Cluster coding
    Jul 2017
    Rhode Island
    2011 BMW 328xi
    Cluster coding
    I bought a used cluster with the oil temperature instead of mpg. Is anyone capable of coding it for me? Obviously willing to pay.
    Midwest, USA
    2008 535xi, 2011 Z4 35is
    You need more than a simple re-coding. You need the mileage and VIN erased from it then you can install it and have it coded to work correctly.
    Jul 2017
    Rhode Island
    2011 BMW 328xi
    Quote Originally Posted by NoQuarterX View Post
    That's fine. Can you do it?
    Jul 2017
    Rhode Island
    2011 BMW 328xi
    Just for everyone's info, I count a used cluster with the oil temperature instead of mpg and just unplugged the old and plugged in the new. Only problem so far is there is a little dot between the mileage and trip odometer. Everything else works perfectly.
    Midwest, USA
    the oil temp is accurate? Great if it is.
    Does your miles show the correct amount? It can change when you install a used cluster.
    The little dot is the tamper indicator. It shows the mileage may be false.
    Jul 2017
    Rhode Island
    2011 BMW 328xi
    Oil temp appears to be accurate. Fluctuates between 1 and 3 lines below the 250 mark when warm and slowly moves up the scale as it warms up.
    It shows my correct mileage (54xxx miles). I'm guessing the tamper dot is showing that the cluster had a different mileage before.
    So, I'm pretty happy with it.
    Jul 2017
    Rhode Island
    2011 BMW 328xi
    Also, that's is also a setting for the instant mpg...so really lost nothing.
  1. hvac control coding
    By Bones774 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-14-2004, 09:05 AM
  2. Replies: 0
    Last Post: 01-08-2004, 02:33 PM
  3. Digital Climate Control coding???
    By axel in forum 1992 - 1999 M3 (E36)
    Last Post: 10-31-2003, 11:06 PM
  4. Forum title coding error
    By hccyong in forum Forum Software Questions & Suggestions
    Last Post: 08-02-2002, 10:20 PM
