2008 328xi coupe A/T with Comfort Access.
Original DME was bench tested and cannot be repaired.
All accessories, fuel pump, starter, etc work properly but DME gives no communication and no spark. Looking at picking up a used working DME from a salvage vehicle but I would like to correct the VIN to match my car. I know its possible and have reached out to several people but no one has responded. Does anyone have the ability to help?
Thank you
I know i could purchase a used Cas key ECU that are already matched but then the VIN number still doesn't match my vehicle and that is important. So either way it would have to be done for inspection purposes
Found a solution to a bad DME. Guy in Dallas can clone your bad DME onto a used one. Make sure your part numbers match and you'll be good to go. Just give him a call, set it up, and ship them out. Very fast turn around time as well
http://www.dallasbmwrepair.mobi/bmw-dme.html
