Results 1 to 6 of 6
Thread: automatic transmission help
    Jan 2016
    portland,OR,USA
    1993 bmw 325is
    does anyone know where i can find the neutral position safety switch/transmission range selector on an e36 automatic transmission (1998 bmw 328ic) its a 4L30E transmission. i seem to be getting alot of different answers online, some claim its mounted in the driver side of the transmission, others say its located under the shiftier does anyone know for sure ?
    Jun 2018
    Chicago, IL
    1995 325iCA
    I've got a 4L30E rebuild guide. How can I share it with you?
    Jun 2010
    NY
    1997 328i
    There is no range selector on the trans itself, it's only what is in the shift selector. The 4L30E on the Land rover or Range rover has it on the trans. On the BMW it is fully electronic.
    What problems are you having?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Jan 2016
    portland,OR,USA
    1993 bmw 325is
    Quote Originally Posted by bobARC View Post
    Well im not sure if the transmission is the problem yet, but if it is ill probably do a manual swap.
    Sent from my SM-N950U using Tapatalk
    Jan 2016
    portland,OR,USA
    1993 bmw 325is
    Quote Originally Posted by Eric93se View Post
    Yeah your right, i spent all afternoon under the car trying to find it, even called my local BMW dealer, and they said it was on the transmission, turns out its under the shift knob
  1. need automatic transmission for my 540
    By frapbimmer in forum 1996 - 2003 (E39)
    Last Post: 10-30-2006, 12:08 PM
  2. 328 automatic transmission
    By skydrvr7 in forum BMW Parts For Sale
    Last Post: 08-31-2003, 08:11 PM
  3. Automatic Transmission
    By oracle in forum 1991 - 1999 (E36)
    Last Post: 08-31-2003, 03:04 PM
  4. Automatic Transmission
    By KnightRider/AMG in forum Off-Topic
    Last Post: 06-24-2002, 01:15 AM
  5. Does anyone have an Automatic transmission?
    By BMWg84 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2002, 01:30 PM
