Results 1 to 8 of 8
Thread: Car wint start
    May 2017
    Maryland
    1986 BMW 325e
    Car wint start
    my e30 wont start, when I turn the key I hear the clicking noise, but no crank at all. I got a new starter installed a few weeks ago. went to the autozone up the street and they checked my battery, starter and alternator and said that everything was good. what do I do now?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    its in park or neutral? its a stick or auto?
    No e30s again.
    May 2017
    Maryland
    1986 BMW 325e
    it’s stick and is not in any gear
    Saskatoon, Canada
    '88 320i Mtech2; 2004 X3
    try removing, cleaning and re-attaching all battery post connections, power and ground strap connections at the starter, check for any loose, dirty or corroded power or ground connections
    ... forty-three years of driving before I get behind the wheel of a BMW .... and I am thinking, "why did it take me so long?"
    ... and then after another 4 years I can't believe that I have two of them !!
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    So autozone tested the battery. And, they bench tested the starter? The solenoid engaged and the starter spun? Assuming that worked. Where is the clicking noise coming from? I agree with above, clean and check all the connections. These wires are 30+ years old.
    Are you getting 12V on the big cable that attaches to the battery? When you try to start it, do you have 12V to the solenoid connection? It could be a bad relay, but to begin with you need to answer those questions.
    The crank circuit is pretty basic.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
    May 2017
    Maryland
    1986 BMW 325e
    thank you guys. i guess it has to be a connection issue.
    when rn i went to autozone they tested my battery, alternator and starter all three passed there test. i’m not sure what test it was. I have to look a little more into it but thanks i think i’ll be able to figure it out with what i have so far. is it possible that either of you can link me to some information of the layout/diagram of the battery connectors? i’m still a beginner and learning as i go
    Dec 2005
    No e30s, again :(
    First, undo your battery connection and clean them with a little wire brish, or somwthing similar. Than reconnect and ser what happens
    No e30s again.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    If you go to wedophones.com you can find a down load able electric repair manual for e30s. Worth it's weight in bits and bytes
  1. Car won't start...
    By kt1 in forum 1991 - 1999 (E36)
    Last Post: 12-27-2003, 05:54 AM
  2. When I start my car....
    By Whatup1049 in forum 1991 - 1999 (E36)
    Last Post: 09-19-2003, 09:11 AM
  3. Help, Car won't start
    By AJCdis3 in forum 1991 - 1999 (E36)
    Last Post: 06-28-2003, 03:00 PM
  4. Help, car won't start
    By AJCdis3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-28-2003, 02:56 PM
  5. Wint tint Squeeks?
    By ///M3ryder NY in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-10-2002, 03:01 PM
