Results 1 to 4 of 4
Thread: Another 1222 Thread
    Ontario
    Two, Two BMW's hahaha
    Another 1222 Thread
    Hello all
    I have read many threads regarding the dreaded 1222 code but mine is different from all the ones i found.
    Car - 91 E30 S50 with VFE kit - 5 to 6 psi . Kit has been installed for years.
    Current problem - car runs great when rolling on the throttle but when you go WOT the car starts to shudder(misfire?) and CEL flashes (stomp code 1222). Once off the throttle the CEL turns off. Car still pulls boost.
    Car idles great right at 14.5- 15. Drive great. At WOT even with the shudder AF is at 11
    I recently changed the plugs to NGK 4091 which were a big improvement over the 4 prong plugs I had. These are gapped to .026.
    The other issue is I can smell traces of fuel vapor under the hood. Seems to be on the intake side. I recently changed the rubber lines that go into the fuel rail thinking that was the issue but it was not. I can not see any fuel leaking anywhere. I can only smell it.
    Is there a vacuum line that if it was leaking would leak fuel vapor?
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hi billyfiction....since the 1222 code deals with the Oxygen sensor in your E30, I've attached a link to one of our tech articles that I hope will help you address the issue. Best of luck!
    http://www.pelicanparts.com/BMW/tech...-O2_Sensor.htm
    -Dmitry
    888.280.7799 | 6am - 5pm PST
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Also, get yourself a boost leak tester and test to see if your system can hold any psi
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Jul 2012
    Lawrence, KS
    1990 BMW 325i convertibl
    My 1990 325i vert is stomping a 1222. A few months ago, my ICV was sticking, and the idle was bouncing up and down. I cleaned it with brake cleaner and stuck it back in and bought a new one. When the new one arrived, I put it in. Non-Bosch.
    Fast forward a few months - it was winter and I wasn't driving it as much since it rains in CA and the car leaks a little here and there, usually on the driver's seat. I started driving the car again and noticed that the car would lurch - almost as if the car was shut off and then turned back on. The CEL light would come on briefly and then go off again. At first I was afraid to drive the car, but then I quickly figured out this only happens within the first five miles of driving the car that day. After five miles, it no longer happens. Even if I drive it to work and let it sit, it will not do it until the next day, when this starts all over again. I drove it to my mechanic, however it didn't stopped by the time I got there. It only lurches 3-5 times in the morning, and then it stops.
    Any ideas? It appears intermittent, even though I have determined there is a pattern.
  1. Another Movie Thread: "Knockaround Guys"
    By Matt Jacobson in forum Off-Topic
    Last Post: 10-17-2002, 04:55 PM
  2. Another Tire Thread
    By TITANIU///M3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-06-2002, 10:36 AM
  3. another m3 thread....
    By swifty in forum 1992 - 1999 M3 (E36)
    Last Post: 05-08-2002, 03:59 PM
  4. Bored - another movie thread
    By Anfanger in forum Off-Topic
    Last Post: 04-03-2002, 05:34 AM
