I just bought a 2007 335i hardtop convertible. Seems to be in great shape. One thing I did not check was the windshield washer operation. Turns out it does not work. I bought a new pump and was going to have someone install when I noticed it has headlight washers as well. I figured the odds would be pretty low that both pumps went bad. So I checked the 30a fuse -- number 84 on my car -- and it was not there.
I then replaced the fuse and figured out why it was gone. When testing the washers, the wipers would not cut off -- in any position. I had to remove the fuse (horrible location by the way) to get the wipers to shut off. The wipers work fine otherwise.
Any ideas? Some short circuit at the pumps? I hope there is not problem in the stalk wiring.
Thanks.
Madbrad
