So I have to get my car to pass inspection so I can get a rebuilt title for it. I have everything figured out except for the air bag codes!
I hit a box spring and it damaged the hood and bumper never passed the tires just dented the body work a little. But the hood and bumper were enough for the insurance company to total it and for the low price of 600 I was able to fix it and get it inspection ready from the damage done from the accident. But now have to fix everything else that was wrong with it before the accident.
Currently there are three codes 6 (firing circuit passenger pretentiomer), 17 passenger seat belt switch), and 21( right side satellite sensor).
I have looked at the Seattle sensor and there's a little corrosion on the back plate but not much. I have been trying to find a way to test these modules and can't seem to find any good ways and was hoping you guys might have some input on where to look.
The light on the dash board does not come on at all and that's what they are looking for.
If you guys have any advice on how to test any if these or see a connection as to what might be causing it I could really use some help because I am at the end of my rope and am running out of time.
Have you tried clearing and seeing what error comes back?
What tool are you using?
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Yes I have and they come right back on next power cycle.
I am using a snap on solus
For the passenger seat, you should disconnect, clean, and reconnect the underseat connectors.
For the sensor, you should just replace.
-Abel
Do you recommend new or is there a way I can test them so I can get a used one?
It's almost always corrosion that takes those out. Used will normally be fine, as long as you are getting the same thing that was in there. No tests that I know of. It's not nearly as simple as a camshaft position sensor, it's an accelerometer.
-Abel
If you're just looking to pass the salvage inspection for now, pull the cluster and yank the bulb.
I think that's already been done. He mentioned no light comes on so it looks like he'll get to pull the dash and put one back in. I'd replace them all while the cluster is out
Yea there bulb does not come on at all and the light has to cycle on then off. I thought about putting a timer on the bulb just because
Could the bulb be burned out or missing?
-Abel
One or the other. I'm going to pull the dash and find out
You don't need to buy one bulb, usually the cluster has bulbs in spots that are never energized (ex.: diesel pre-glowing, rear foglight). Some Z3's also have a cruise control bulb in the cluster that never turns on for some reason (unless you tell it to with INPA). Just swap them around, that's what I did.
The airbag light actually has two bulbs - the main one that can be swapped and another one that is part of the board in the cluster. The second one should light up (albeit not as brightly) if the main bulb fails. If you have neither illuminating, then you may find that someone has removed the main bulb, and stuffed something in the hole to mask the second bulb!
When I bought my car the airbag light had been jerry-rigged by lining it to one of the other dash bulbs that illuminates then goes off - I reinstated everything, sorted the typical bad connection under the seat, cleared the codes and all was well.
Z3 side impact sensors, and the DSC sensors as well, fail because they get wet from interior leaks. I cross the numbers using ETK (realoem) to E36, E46, or E39 and get a used one from a sedan.
/.randy
I once had a code 21 for the right side satellite sensor come up while driving. Unplugged the battery, took the seat out (god is that thing heavy), unplugged the sensor, sprayed contact cleaner in it, put it back together, cleared the code and the error never appeared again. The sensor had some very light corrosion on the backing plate towards the frame rail, the electrical plugs were bone-dry inside and outside though. Part number of that sensor is 65.77-8 381 564.
So I do not have a manual for the car so I have been piecing my information together. But I have ran into a but of a wall...
Attached are some pictures of the plugs I have.
Red is the seat belt tensioner
The small black one is the seat belt latch switch.
The big white and black ones are for seat movement power
But the rounded one I think is the occupancy mat sensor but I don't have a female end to plug it into and on the harness side I don't know what the small white plug is for.
What's does the occupancy sensor plug into on the harness side
And what is that small white three wire plug for?
Do you have the occupancy sensor box? I just replaced my passenger seat and I think that is what plugs into those.
Here is one from ebay:
https://www.ebay.com/itm/BMW-z3-e53-...e/291787575353
1998 Z3 1.9L Dinan Stage 3.
Here is a bypass unit on Ebay. The bypass emulator is a resistor with a plug attached to it.
https://www.ebay.com/itm/Seat-Occupa...kAAOSwFJBZQq1K
You can try checking your driver's side seat for the sensor box. A previous owner of my car had the seats re-upholstered and the seat bases had been switched. I was hopeful that the occupancy mat still worked so I switched the seat bases (a lot of work!) but alas, I had to resort to the bypass unit. Note that the airbag will deploy if the car thinks someone is in the seat.
Wayne
1998 M Roadster
1994 Honda ST1100--sold
2017 Yamaha FJR1300ES
