Results 1 to 25 of 25
Thread: Any suggestion what else to do while servicing the differential mount bushing...
    Feb 2004
    san diego
    ...it depands
    Hi all,
    I am planning on removing the differential to service the mount bushing. And I had some questions that I wanted to run them by you guys.
    First question: is there any other items you would recommend while the diff is out and unmounted? The actual diff seems to be in good running condition so I don't think it needs to be rebuilt. But one of the inner axle boots is worn and rusted and looks like it could be serviced, and I will probably service all of them them. Is there anything else you would recommend?
    (Note: Trailing arm and subframe bushings were serviced. Subframe reinforcement is saved for another day.)
    Next question. Can the diff be unmounted without removing (or hanging) the exhaust? And has anyone been able to remove the diff cover without unmounting the diff? From what I've gathered and seen, it seems less-likely. But I wanted to find out if anyone was able to do it.
    TIA
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    You need to remove the back section of exhaust and lower the subframe enough to clear the diff mount. Or drop the diff. The top 2 bolts holding diff to subframe are difficult to get to and generally require dropping the subframe. Given that starting the bolts back into the diff when trying to do so while Subframe is still in the car is probably the most stupidly simple but difficult thing to do, ever, I would drop the subframe with the diff still attached enough to remove the cover. FYI If you are swapping the diff cover bushing, DO NOT use anything but OEM. Harder bushings will do nothing but damage the mount/rear pan areas of the car.
    Dan "PbFut" Rose
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    You can install the stud kit from Condor, which will make reinstallation of the diff much easier.
    I wouldn't trust their torque specs, though - theyre too low.
    If the diff isn't leaking, I'd probably leave the rest alone.
    You can buy the bushing removal/install tool that allows you to remove the bushing without completely removing the diff.
    It's an absolutely beautiful and well thought out tool made by Bosch, but it will take 3 weeks to arrive from Germany. I bought it (83-30-0-492-179) from getbmwparts.com for $117 shipped.
    I bought it but on the second use the bushing was so stuck that I totally destroyed it.
    Mesa, Arizona
    2000 Z3 M-Roadster
    Replace all of o-rings (output shafts), lock ring...etc. Using a punch or something similar, mark how the driveshaft aligns with the pinion gear input. I did this when i had my differential out.
    Tony
    "You can't sign away negligence."
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by PbFut View Post
    Thanks, these really helps! I will most likely take the diff to a shop to get the bushings pressed in. I will be surely replacing with a oem bushing.
    Quote Originally Posted by scenturion View Post
    You can install the stud kit from Condor[/URL], which will make reinstallation of the diff much easier.
    The Condor stud kit looks interesting, I will need to get more info. Thanks!
    Quote Originally Posted by ProductUser View Post
    Awesome, I added them to the list. Thanks!
    - Zach
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    As a counter point, I never drop the exhaust, and don't have any issues removing or installing the top bolts. Even the M with the spacer. I really hate messing with exhaust... I do transmissions and driveshafts without removing it. Lately the only times I remove the rear cans is to install Randy's kit.
    Kent, Ohio
    1998 M Roadster
    Why are you servicing the diff mount bushing? Is it because the bushing has failed, or as part of a maintenance schedule? If it is just as part of a schedule, but not broken, I say let it be. You don't say which Z3 you are doing this to, but if it's the ///M, and you are pulling the axles from the hubs, do yourself a favor and rotate axle shafts from side to side--they are the same and will last quite a bit longer that way, as they have worn all this time in the one direction (a trick from Randy F's play book). There is a special tool for pulling and reinstalling the axles into the hubs you may want to look into--it may be you don't need it, or it may be essential--could go either way.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Good to know. I wish I had done this when the diff was out. Maybe next time I need something to do...
    What do you recommend for popping the axles out of the hub? A sledge + punch didn't work on a buddy's Z3.
    Was thinking about one of these.
    Feb 2004
    san diego
    ...it depands
    Thank for the advise, Randy. I found additional sources to do this project without dropping the exhaust as you mentioned.
    - Zach
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by Mr Bingley View Post
    Thank for the tip on switching sides for the axle shafts, Mr Bingley. That is a great suggestion! I usually go by visual inspection. And I haven't noticed anything major. But I do feel the thumping sound shifting between 1-2-3 gears occasionally and gradually more . I will probably take time to gather a complete list of things to service then do them all at once.
    - Zach
    May 2010
    DFW, TX
    318i, 540iT, Z3M
    everytime I've used something like this, it's pulled the hub OFF the bearing inner race...
    Last time I pulled my half-shafts, I pulled them out of the diff-side, then just tapped the end of the axle on the hub-side with a dowel and a hammer.
    Pulling the axle back into the hub has always been a chore though
    Aug 2017
    Quote Originally Posted by NLu View Post
    ...Last time I pulled my half-shafts, I pulled them out of the diff-side, then just tapped the end of the axle on the hub-side with a dowel and a hammer...
    +1
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by nevan View Post
    As recent as last night...
    Feb 2004
    san diego
    ...it depands
    That looks so good, Randy!! Definitely puts mine in shame.
    Another question for folks, has anyone heard of SureTrack Axles? How are their quality? They seem very affordable that I am tempted to replace the whole axles instead of servicing the boots. What do you think? Any thought would be appreciated.
    - Zach
    Dec 2007
    Great Dismal Swamp
    Never heard of them, but I will wager they don't make M axles.
    /.randy
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Do people actually replace the axle to diff bolts every time? They have serrated flanges, but I don't think theyre torque-to-yield?
    SW Florida
    (no)
    If I encounter any that some hack let an impact gun/socket mangle the head, or if corrosion has gotten to them, I keep a set in stock for those occasions, Most of the time, I media-tumble them and they look as good as new; if there was any shortcomings in doing that__for the last fourteen (14) years__it would've shown up by now. Actually, more years than that, as I'd swap out the 3.15:1 for a 3.73:1 in my '01 with some frequency between '02 - '04 only replacing the bolts once.
    Tim @ BMW of Dallas
    98 Z3 2.8
    Why do people spread this rumor? I've had three popped welds in my roadster for many years, and I swapped to a poly mount along with the sub-frame bushings. I drive like an ass, and nothing has gotten any worse in ~30k of hell. Also used poly in all 7 rear mounts of my coupe and guess what... No problems.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Dec 2007
    Great Dismal Swamp
    Owned by a middle-aged female lawyer.
    /.randy
    NY
    skateboard
    I guess she gets down
    ― George Orwell
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by GG///M3 View Post
    Lol,
    Here is my latest update. A bit of setback actually...
    Good news is that diff mount bushing and the actual diff itself are in great condition.
    Bad news is that I need to figure out what to do with the diff cover now.
    I'm kicking myself for opting out the dual/single ear with Randy's reinforcement kit... And I have to improvise now...
    - Zach
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    FWIW I had a similar crack in my spare diff housing fixed at a local welding shop for <$100.00.
    It's a bummer that you'll have to drop the diff and do it over, but its more time than money.
    Feb 2004
    san diego
    ...it depands
    Thanks so much, scenturion. Your post brought hope back. I am talking with my welder so hopefully he will be able to fix it...
    - Zach
    Aug 2003
    Dallas, TX
    Z3M, X5M
    anybody using a poly diff bushing on a reinforced diff mount and trunkfloor?
    -Phil
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by Z-Thrizzle View Post
    As Phil mentioned, I am also curious if poly bushing would be a viable option (particularly with Randy's reinforcement kit). Could anyone with experience please chime in? TIA!
    - Zach
