My E32(M60B30) 1992, has been an endearing car but I have a rough shift between 2nd-3rd. Not noticeable at all when cold, car has to be driven for a while to notice it. My brother brought this car back to Australia from Hong Kong but initially from the UK, now mine. He had the G/box rebuilt because it was jerking everywhere but we are left with this rough change and the workshop gave up on it - they even sourced a 2nd hand valve body to no avail. Engine test reveals no faults/codes other than a persistent CAN-1 error which I'm told is a communication error?? Car only has 160,000 kms on it but has had some lengthy periods where it sat idle with stale fuel and the car certainly ran better after some treatments went through it. Prior to there was indication on start-up that some sensors may be glazed etc but running well presently. I'm also getting the occasional 'trans prog' error come up that clears once I push the shifter back then forward. It's been an ongoing pain in the backside and I really need to clear it up before I press on with this project. I understand it's a common one but I'm hoping that grab bag of info might point somewhere??
What is the VIN for this car?
For the E32 730 M60 there was an EPROM update for the ZF 5HP18, because there was some hard shifting. This refers to 730iA (M60) with A5S 310Z = ZF 5HP18 and VIN smaller than DD 44 532
Here the German version translate that
Fehler der elektronischen Getriebesteuerung (EGS) beim 730iA V8 (E32) mit 5- Gang-Automatikgetriebe A5S 310Z (5HP 18), Eprom-Tausch auf Softwarestand D3000
Symptome (Auswahl):
- Harte Hoch- und Rückschaltung in verschiedenen Fahrzuständen, schlechter Schaltkomfort
- Elektronische Getriebesteuerung schaltet sporadisch auf Notprogramm, Fehler 100 (Gangüberwachung) im Fehlerspeicher
- 3-2 Zurückschaltung unkomfortabel, bei langsamen Gasgeben (35 - 50 km/h) mit starkem Stoß, tritt bei schnellem Gasgeben nicht auf
- 4-5 Hochschaltung bei Lastrücknahme hart
- 5-4/4-5 Pendelschaltungen unter leichter Last im Geschwindigkeitsbereich von 80 - 85 km/h
- Sporadisch harte Schaltung nach abgebrochener Volllastbeschleunigung aus ca. 120 - 155 km/h
- 4-5 Schaltung wird unter leichter Last im Geschwindigkeitsbereich von 80 - 85 km/h abgebrochen, d.h. es wird kurzzeitig, evtl. mit hartem Schaltstoß wieder der 4. Gang genommen. Dieser Vorgang kann sich bei konstanter Fahrt (80 - 85 km/h) unter leichter Last mehrmals wiederholen (Pendelschaltungen)
Betroffene Fahrzeuge: 730iA (M60) mit A5S 310Z und Fahrgestellnummer kleiner DD 44 532
Vor dem Eingriff: Softwarestand der EGS per MoDIC oder DIS auslesen. Ist bereits Softwarestand D3000 verbaut, liegen mechanische Probleme vor (z.B. hydraulisches Schaltgeraet, Widerstand Drehzahlfuehler etc.)
Teilenummer EPROM D3000: 24601422532
http://www.7-forum.com/modelle/e32/e..._egs/index.php
Last seven digits are DE25134....
Check the chip in the trans for the number shown in the link. No idea if these chips are still available from the dealer. If not, try to get a used TCU.
Or if someone has a spare TCU with the upgraded EPROM and can send me the chip, I can make some copies, have the stuff here to read and copy, would have to check which EPROM, as I only have spare EPROMS for the Motronic performance chips on stock
VIN: WBAGD22010DE25134
Type code: GD22
Model: 730I (EUR)
E-F-R series: E32
Series: 7
Type: LIM
Steering: RL
Doors: 4
Engine: M60/1
Displacement: 3.00
Power: 160 (217 hp)
Drive: HECK
Transmission: AUT
Paint code: 294 - LAZURBLAU METALLIC
Prod.date: 1992-07-21
S216 HYDRO STEERING-SERVOTRONIC
S240 Steering wheel, leather
S302 Alarm system
S401 Lift-up-and-slide-back sunroof, electric
S416 Roller sun visor, rear lateral
S430 Interior/outside mirror with auto dip
S438 Fine wood trim
S459 El. front seat adjustment w. memory
S472 Armrest, front, driver/passenger
S508 Park Distance Control (PDC)
S528 AUTOMATIC AIR FLOW CONTROL
S534 Automatic air conditioning
S553 On-board computer IV with remote control
S564 Interior light package
S676 HiFi speaker system
S687 Radio preparation
S823 Tropical version
S850 Additional Export tank filling
S925 Dispatch protection pack
Righto, very interesting - thanks for that. That will be a tomorrow job but while in Hong Kong my brother got slaughtered on repairs and was even charged for a new Gbox he never got. If it had the right chip it's entirely possible it got nicked and swapped, some amazing shonkery goes on there, especially if you are a 'Gwalo'(not a local) .
This document covers what Erich was explaining above:
http://www.meeknet.co.uk/E32/E32AutoBox.pdf
My BMW Repair YouTube Channel
Tim, that is for the 5HP30, his E32 730 M60B30 has a 5HP18, basically the same symptoms, but the EGS data versions are different for the 5HP18.
Just in case you cannot get the EPROM D3000: 24601422532 from the dealer anymore as NLA, let me know, I know someone in Germany who might be able to help.
Ok,
the number on the chip is 3 337 633 114
002 196 GC5G
On the TCU I have Bosch 0 260 002 196 (GC5G)
1 421 089
I also have a sticker on the TCU with my VIN, plus the digits 1421089, below it 1421334
002 196 is indeed the old outdated chip with version C2100X. I can get you the new version, PM sent.
Just a quick question Matt, is it a constant or occasional thing? The reason I ask is that I have a random hard shift, just wondering if it is a program issue? I just put it down to a 'way I was driving issue' but this thread has got me thinking!
I originally put it down to a lot of cruising or sedated driving, then a period of more aggressive driving, then whilst driving more sedated it seems to hard shift occasionally, maybe it's not my driving (Though mine is a 5hp30)
This refers to 5HP30
Complaint......................................... ............................................Constr aints and test conditions........................................ .................................................. ........................................ Remedy
Item 3: 540iA, 740iA/E32 and 840iA with EGS
Hard shift from 1-2 under small load....................................EGS data version 2324, 2425, 2628...................................Convert EGS control unit to data version 3232 by replacing the EPROM. EPROM part number 24 60 1 422 397 ECE, 24 60 1 422 399 Japan
Item 4: 540iA, 740iA/E32 and 840iA with EGS
Hard shift 3-4................................................. ................EGS data version 2324,2425,2628,2729.......................Convert EGS control unit to data version 3232 by replacing the EPROM. EPROM part number 24 60 1 422 397 ECE,24 60 1 422 399 Japan
Note: This only applies in the case of vehicles with a transmission with serial number 18584 or lower. If the problem still exists after the EGS control unit has been replaced and after a sufficiently long adaptation test drive, the hydraulic control unit should also be
replaced. Part no. 24 34 1 422 136
Item 5: 540iA, 740iA/E32 and 840iA with EGS
A jolt when changing down 5-3 under load......................EGS data version 2324,2425,2628,2729 ......................Convert EGS control unit to data version 3232 by replacing the EPROM. EPROM part number 24 60 1 422 397 ECE. 24 60 1 422 399 Japan
Item 6: 540iA, 740iA/E32 and 840iA with EGSThe converter with lock up clutch judders when it cuts in at a speed of approx. 85 km/h, or you can hear a droning noise at 85-100 km/h under load when the converter with lock up clutch is closed
EGS data version 2324,2425,2628,2729,
Item 7: 540iA, 740iA/E32 and E38 as well as 840iA with EGS and AGS
The vehicle takes more than 2 seconds to react when moving the gear selector from N to D or from N to R.
Oil level OK, Gear selector position OK, Transmission with serial number 70967 or less
Both plain compression rings on the converter support shaft should be replaced with modified versions in accordance with the enclosed installation instructions
Note: Modified plain compression rings have been fitted in series production as from transmission serial number 70968. Parts required for each vehicle: 2 x plain compression rings Part no. 24 23 1 422 387, 1 x oil seal ring Part no. 24 31 1 421 583, 14 x sealing rings Part no. 24 31 1 219 165, 2 x oil seal rings, Wiring harness plug Part no. 24 34 1 421 736, 4 x oil seal rings Intake/pressure duct Part no. 24 34 1 421 145
Item 8: 540iA with AGS from 09/93 - 11/94
Unexpected and hard shift 5-4 and 4-5 under constant load. It takes less than a second to shift up or down - AGS control unit with data version 2626
Convert the AGS control unit to data version 2929 by replacing the EPROM . Note: The control unit fitted in series production since 12/94 is OK. EPROM part number 24 60 1 422 562 ECE 24 60 1 422 564 Japan
Item 9: 740iA/E38
Poor shifting, in particular 2-3, 3-4 and 5-4 are hard...................AGS data version 2020,2424,2828,...............Convert the AGS control unit to data version 2929 by replacing the EPROM. EPROM part number 24 60 1 422 560
Shogun, does this mean that I need to upgrade my EPROMs to data version 3232, is this still available?
Have no idea, maybe you ask the dealer for 3232 EPROM part number 24601422397 ECE
Maybe a cpl. used EGS control module with that EPROM is cheaper than a new EPROM from the dealer.
But first check inside your control module what is actually installed.
Procedure here as example for the 5HP18 http://www.7-forum.com/modelle/e32/e..._egs/index.php
