Results 1 to 8 of 8
Thread: E93 (Vert) - Rattles in front windshield pillars (over bumps)
    May 2017
    Ontario, Canada
    335i E93 N54
    Hi All,
    In my E93 (convertible) when going over bumps I get rattling noises in my front windshield pillars.
    This is the case whether the roof is up or down.
    The latching works as expected (or certainly appears to).
    I'm guessing it's part of the latching mechanism - but it's noisier then I would have imagined.
    Just wondering if this is common - and if anyone 'corrected' or improved on this.
    Thanks for the feedback!
    Sep 2015
    Irvine, CA
    330ci convertible
    Quote Originally Posted by Codes2 View Post
    Hi All,
    2008 e93 I have the same problem only on the drivers side, I have not found a solution yet. Hope someone chimes in with one.
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by soulmaker1 View Post
    2008 e93 I have the same problem only on the drivers side, I have found a solution yet. Hope someone chimes in with one.
    Interesting. Mine is much more pronounced on the driver side. Initially that is where I heard it from. Now passenger does it too.
    Dec 2016
    Gonzales Louisiana usa
    2008 335i convertible,
    on my 08 it was the visor mounts had rattled loose,easy to tighten
    Jan 2017
    Redmond
    1989 325ic
    so, Codes2, soulmaker1, did tightening the visor mounts fix it?
    Sep 2015
    Irvine, CA
    330ci convertible
    It wasn’t the visor mounts on mine. For now I just live with it.
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by bobdavisnpf View Post
    I did check when you posted that, thanks.
    However, that's not it for me. Rattles inside both front pillars on hitting bumps.
    May 2017
    Ontario, Canada
    335i E93 N54
    Well, the rattling only gets worse. Survivable though. No fix in sight it seems. Just there on bumps, both sides.
    Not the visors and I don't recall hearing it when the roof is down.
    That said... I love my E93 on a warm clear day with the top dropped. Worth the odd rattle when top's up.
