Results 1 to 6 of 6
Thread: Search function down - Racelogic Full Throttle Shift
    Jul 2002
    Long Island, NY
    98 Turbo M3, 04 E53 X5
    Its irritating that the search function is still down...
    does anyone have the option for Full Throttle Shift on there RLTC?
    If so what did you use for a switch?
    98 Fern Green M3/2 - Precision 6870/AR Designs Twin Scroll/RK/E85
    2017 Toyota Tundra Crewmaxx - Family Whip
    2011 Pierce 75' Quint - Fire Apparatus West Islip FD
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    Not using racelogic stuff but I'm currently using the clutch switch for full throttle upshift events. The switch activates a shift cut function that kills the engine for about 150 ms and also enables a rev limit that correlates to engine speed for the gear you're going into until the clutch releases.
    It's really handy because if you're a little bit slow or fast on the shift the engine speed is held at the correct rpm for the next gear when you release the clutch. I found that just using a straight cut time meant I was either waiting for the power to come back in because the cut was too long, or I couldn't complete the shift in time. With an h pattern box I found myself faster on the 1-2 and 3-4 shifts than I could be on the 2-3 4-5. YMMV.
    But yes, the clutch switch should work for you. I believe it's just a ground reference so check that the racelogic box is looking for that.
    Vancouver, BC Ca
    1993 325is
    I don't have the function enabled, but if I were doing it, I'd be using the clutch switch. In the case of RaceLogic, it is just a preset rev limit active while the switch is open (closed).
    Jul 2002
    Long Island, NY
    Quote Originally Posted by Kevin325i View Post
    Quote Originally Posted by jakermac View Post
    Thanks guys but I thought I read we couldnt use the stock clutch switch. Is anyone using it?
    Mar 2008
    Canton, Ohio
    02 525it, 97 M3, 08 X5
    When I still had my m3 I was using this feature. I mounted an additional switch right by the factory clutch switch. I can’t recall the exact reason why the factory clutch switch wouldn’t work, but I know I didn’t add it just for fun. In the RLTC software on the rev limit tab you can tell it if your switch is normally open, or normally closed to ground.
    Jul 2002
    Long Island, NY
    Quote Originally Posted by Keith1054 View Post
    ok good to know, Im reading about guys using some sort of motorcycle switch that is adjustable...
    https://racelogic.support/02VBOX_Mot...Throttle_Shift
