- Starter removal I知 stuck
What痴 the secret on removing the last nut on the driver side toward the bottom? I know a 11 mm nut needs to hold onto the hex style nut while the bigger nut towards the front is a 16 mm. I知 doing this under the car by myself it痴 driving me crazy.
Sent from my iPhone using TapatalkIMG_0891.JPGIMG_0892.JPGIMG_0893.JPGIMG_0890.JPG
No e30s again.
Thanks fellas I値l check back in when it痴 off
Take a look at the link below for the procedure guide - hope this helps you out a bit too!
https://www.pelicanparts.com/bmw/tec...84-Starter.htm
- You may not post replies
- You may not edit your posts
Forum Rules
