Page 1 of 8 12345678 LastLast
Results 1 to 25 of 187
Thread: Puff's "What's A Turbo?" '95 E34 Build Thread
    Feb 2017
    Minneapolis, Minnesota
    1995 BMW 525i/5
    Puff's "What's A Turbo" '95 E34 Build Thread
    Intro:
    Howdy!
    A couple years ago I bought a '95 525i/5 for $1000. It was sitting at around 240k at the time of purchase and I've run it up to about 275k in my time of ownership.
    Almost as soon as I signed the title I was fantasizing about turboing the car at some point, and now I finally have the time/funds to do so. The goal is to hit somewhere in the 350whp range without completely demolishing my bank account or car. Without further ado, let's give it a shot.
    UPDATE (11/18/18): my bank account has been completely demolished.
    Disclaimer: I will be asking dumb questions. Please be patient with me as I learn the ropes. I've spent a lot of time perusing turbo build threads, but I'm pretty sure I've learned next to nothing.
    Legend: Anything with a next to or in it means I'm a little unsure if what I have is correct and would appreciate anyone's insight or suggestion on the matter.
    A list of parts I have so far:
    Disclaimer: as of 2021, a lot of this has changed. See later posts for changes!
    - Ebay HX35 (May consider getting something a little less...Ebay ) Ended up getting a new Garrett 60-1 journal bearing. eBay turbo sold!
    - Tubular T3 top-mount exhaust manifold that was used on a running FI setup (per the previous owner) Started with an E36 CXRacing top-mount, but the wastegate positioning didn't work well and it prevented me from using A/C. Went with the Rapidspool E34 top-mount instead.
    - Blitz BOV Ended up with a Tial BOV instead
    - Tial MVS 44mm Wastegate
    - A small ebay intercooler
    - An MS3 Pro, the wiring harness that comes with it, and a gutted MS41 DME case with the 88-pin connector and 6 stock coil drivers ended up switching to a Link G4+ E36 PNP due to the MS3 dying on me
    - LC-2 Wideband
    - A lot of time and patience
    A to-buy list:
    - MAP Sensor Done - 3bar GM MAP
    - Charge piping Done - Ebay Universal Piping
    - Oil feed and drain + fittings Done - Aeroquip fittings and hose for drain (-10AN), Rallyroad VANOS feed
    - Gauge(s) for interior Done - VEI Open-frame gauge
    - A new wiper reservoir to relocate
    - Muffler(s) Done - Vibrant Ultraquiet Resonator, Borla XR-1
    - VANOS banjo bolt for turbo oil supply Done - Rallyroad VANOS banjo bolt
    - Catch can Done - Vibrant Catch Can (Vented to atmosphere)
    - Injectors Done - Siemens Deka 60lb
    - An electric fan to replace the stock one
    Here's the to-do list in no particular order:
    [x] Swap the M50TU to a refreshed single-VANOS M52 (ARP Studs and VAC .120 headgasket) -(Ended up with an MLS 0.089) Edit: switched that to a CES cutring and copper spacer
    [x] Build the adapter harness with the MS3Pro
    [x] Install the manifold and turbo
    [x] Install the intercooler and charge piping
    [x] Get a downpipe and exhaust welded up
    [x] Install exhaust
    [x] Tap the oil pan for oil return I've read something or another about using the stock drain location with a new bolt and a T
    [x] Install oil supply and return
    [x] Install the MS3Pro/Adapter
    [x] Tune away
    Pictures:
    '95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
    Feb 2017
    1995 BMW 525i/5
    Small shipment of things arrived today!
    - LC-2 Wideband
    - Lots of solder
    - Ring connectors
    - Braided sleeving
    - Heat shrink (I actually got the wrong size, so I'm ordering some additional)
    Does anyone have a pinout for the MS3Pro to M50TU harness? I've made something of a pinout, but I'd like to verify with a working one.
    Apr 2006
    Minnesota eh?
    86 325es
    Is that an E36 manifold? I don't think there is room to do bottom mount on an e34
    Feb 2017
    1995 BMW 525i/5
    No, it was off of a boosted E34 also; top mount!
    Feb 2017
    1995 BMW 525i/5
    Quick question: has anyone successfully blocked off or removed an internal wastegate? I have this ebay turbo which looks to be of decent quality, but I could also just go for one that already doesn't have an internal since I have the Tial 44mm. Thoughts?
    Nov 2013
    VA
    E36
    Quote Originally Posted by CallMePuff View Post
    Get a quality turbo that can utilize the tial 44mm ewg. Looks can be deceiving....
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by bmw328m52 View Post
    I can work with that. It's turning out that this "setup" that I bought last year which included 2 manifolds, a stock fuel rail (why?), the BOV, an ebay wastegate, and some piping was not really worth it lol. I've replaced the turbo (which will seemingly get replaced now), the wastegate, and won't be using the fuel rail. Expensive mistakes! Thanks for the insight.
    Feb 2017
    1995 BMW 525i/5
    Today I got the copious amounts of colored 20g wire that I ordered along with the correctly sized heatshrink tubing. We've also got some .31" diameter solder, ring connectors, the MS3Pro, and the 88-pin connector with the stock coil drivers. I'm going to attach my pinout; if anyone has an inkling of info for an OBD1 M50TU/M52 to MS3Pro, let me know!
    https://docs.google.com/spreadsheets...pub?output=pdf
    Feb 2017
    1995 BMW 525i/5
    Hi all,
    I have the option of going for a new 5858 journal bearing for about $1000 or a Garrett 60-1 journal bearing for $850.
    Opinions? I'm trying to educate myself on turbo specifications, but I'm sure your collective knowledge is greater than I can learn!
    EDIT: Borg Warner also an option?
    Feb 2009
    Arizona
    1998 e36
    You will blow the engine before you even get it to run right, happens to 90% of the noobs. Looking at the parts you already bought, I know it is going to be a mess. E34 is a heavy car and 350hp is nothing, stock E34 540i will be able to keep up with you. When you put your whole plan on a paper you will realize it is a waste of money and time.
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by hakentt View Post
    While I appreciate your concern, telling me this benefits me in no way if there's no advice to accompany it. What exactly makes it a mess?
    Apr 2006
    Minnesota eh?
    86 325es
    don't feed the troll
    Virginia
    97' m52 turbo
    350 is plenty of fun. And the build could be done for <3k
    I wouldn't build a 350 car to go around and try to race it anyway... Who would
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by 328iFun View Post
    Yeah it's basically just to not have the stock 180-something horses. I'm trying to do it right though so that it can be pushed a little further since I've read about people just pushing it a little further once the current power gets stale.
    Sent from my Nexus 6P using Tapatalk
    Feb 2017
    1995 BMW 525i/5
    My sights are aimed in the general direction of a Precision 5858 .82 A/R or a friend has a Garrett 60-1 for sale at .63 A/R.
    Which one of these is going to work best for the 2.8L?
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    HackerTT giving unsolicited shitty "advice" again. What a surprise? He also said my standalone would "Never run right" but while I have 1 small bug to work out still it runs just as well as the car ever did stock and I didn't lose any OEM features. My cluster works 100% (unlike his) EVEN the MPG gauge will work once I connect 2 wires!!! He gives us shit if we take more then 6 months to build a car but I did mine in a year once I pulled the engine and it took him 3-4 according to the pictures I found online of him doing it on another car. I mean if I had a second try at doing all of the stuff I did on mine I'm pretty sure it would only take me a couple months to build soo.....
    Rant out of the way.... I have a Genuine Holset HX35 on mine. I LOVE this turbo for a street car but I would STRONGLY advise getting a real one AND a 14cm housing to go with it. This turbo can easily make 400 whp, I'm making 352 at 12 PSI and still cranking it up (on E85). Mine was a $200 used one on ebay that said "for core or rebuild" when I got it I inspected it and everything seemed fine so I just put it on and it's perfect, there's literally nothing wrong with it. HX35's just last forever.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Feb 2017
    1995 BMW 525i/5
    So I went ahead and bought a Garrett 60-1 to replace the HX35 eBay rep I was going to use. It's funny the things I find myself replacing before even building anything.
    Dec 2009
    Halifax, NS, Canada
    '90 325is '88 M3 '87 iX
    Vibrant Performance make really nice muffler/resonators. I'm running their 3" ultraquiet resonator and a 3" streetpower muffler on my car and they were beautiful pieces to work with (although a little on the loud side). I used their V-band clamps as well. They're really nice (quick release, replacable tee bolt, no fucking nyloc nuts, alignment lip) but they are expensive and warp when welding(as all vbands, just go slow and clamp everything together until all the welding is done.) There are a few cheaper alternatives out there, but most stuff isn't quick release.
    Catch can. I tried the Mann Provent that had lots of people ranting and raving about it, and honestly it sucked. I think running the largest diameter hose you can from the valve cover to a vented catch can is probably the easiest approach besides venting straight to atmosphere.Injectors: Lots of people run Siemens Deka 60's or 80's. They're cheap and are the right size, but they hate operating at low pulsewidth so idle is rough. Also fakes are a problem. Above that, ID, Deatschwerks, FIC are all options that will have less variance and better idle quality for a big price increase.
    Electric fan: a stock clutch fan will flow more than whatever electric fan you're probably going to install. I'm not sure what E34 aux fan setup is like, but if it's similar to the E30's electric fan+rad mounted temp switch, look into the "official electric fan wiring thread" on r3vlimited.
    Oil drain: With the engine out of the car, it's easy to drill and tap either the block(behind the AC bracket, or thereabouts) or the side of the timing cover for an AN union, or AN-NPT fitting. Braze/weld/JBweld/whatever. It's no extra effort vs the oil pan, but then the return is guaranteed to be above the oil pan oil level, and it gives you one less thing to disconnect if you need to pull the oil pan for any reason.
    Feb 2017
    1995 BMW 525i/5
    Quote Originally Posted by Northern View Post
    Would 42lb/hr Bosch injectors be suitable for the job? From what I've read, that should technically be enough headroom for the power I'm hoping to make.
    The idea was to keep the clutch fan and replace the stock aux fan with a slimmer one. The shape of the front bumper on the E34 limits the options for intercooler sizes. I have one that fits without making any modifications to the bumper, but the stock aux fan is way too thick. I believe another member here helped me determine how to make that work.
    If it's tapping into the side of the timing cover, is there a risk that the fitting welded in will stick too far through the cover?
    Thanks for all of your insight! Incredibly helpful.
    Dec 2009
    Halifax, NS, Canada
    Most size charts say that those will be alright for 350-400, fine if you don't plan on upping the boost down the road.
    On my E30, I have a 3" intercooler, then a Spal pusher fan(iirc it's 1.85" thick), then a Z3m rad, and it all just barely fits. You should be able to straight swap the stock fan for a skinnier one.
    If it's tapping into the side of the timing cover, is there a risk that the fitting welded in will stick too far through the cover? .
    Yeah, definitely take the time to plan out where you want it. Make sure there's nothing close to block oil flow and cut down the fitting before you weld it in so it protrudes as little as possible.
    Feb 2017
    1995 BMW 525i/5
    What clutch/flywheel do you guys think is best suited for daily driving? I figure if I'm pulling the trans and motor to put the M52 block in, I might as well prepare a stronger clutch.
    EDIT: I've heard whispers of some clutch/flywheel combos chattering. Is the stock dual mass flywheel plus an FX clutch good for driveability?
    Feb 2017
    1995 BMW 525i/5
    I'm thinking of going with UUC's M5 clutch/flywheel kit. While more expensive than I had originally planned, I have a feeling it'll retain the stock clutch feel for the most part and not chatter. I'd also like to do this right the first time around so I can get fast and reliable instead of fast and cheap.
    Apr 2006
    Minnesota eh?
    86 325es
    I've ridden in an M3 with UUC's cerametalic clutch and it drove great and held a good bit of power. For injectors you had just as well get the 60 lb siemens. They are cheap and there is no downside to them at all over 42's.
    Feb 2017
    1995 BMW 525i/5
    I was going to buy the Bosch 42s from a member on here for $100. He used em on his turbo build and they looked to be clean; he said they worked just fine when he took them off.
    Comparatively, the Siemens 60s are $320 for a set of 8. Should I just bite the $220 bullet?
    Feb 2017
    1995 BMW 525i/5
    Update for today! Pictures below.
    Received a UUC M5 Performance Organic Clutch/Lightweight flywheel combo from a guy that was letting it go barely used. Came with the throwout bearing and the flywheel resurfaced. He informed me that it should be rebalanced and to get new flywheel bolts. Anything else I might need off the top of anyone's head? I'll be doing some research myself also.
    Also received mint 60lb Siemens Deka injectors; delivered in a bundle of napkins. Dropped off by a stork.
    Still working on the MS3Pro adapter and making some good headway there, learning a lot. Hopefully my solders hold up, especially on the coil drivers since I had to bend the pins after the fact.
    Also wanting to get this adapter finished and try running it on my current stock M50TU to ensure it's all wired correctly before throwing it into a low-compression M52 with turbo goodies on it. Waiting to pull the M50 until I can ensure the MS3 is working properly.
    Clutch/FW/Throwout bearing:
    60lb Siemens Deka Injectors:
    MS3Pro Adapter:
