Didn't quite get where we were planning to with the boost level but... it's still pretty good for my first custom turbo build. We were running into ignition break up at 12+ PSI. I'm running the NGK BKR7E's gapped at .22 or something like that. I think this setup still has 400 whp in it easily at 16 or 17 psi if I can figure out the ignition issue. I have some brand new OG Bremi OEM coils that I'm gonna start with because mine do look extremely old and a couple look like they may have been really hot.
This was the 12 PSI run, even there it had a small hiccup with the ignition unfortunately.
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
What size exhaust housing are you running? 12 cm?
What compression are you at?
www.facebook.com/Undr8dEmpireLlc Instagram: @UNDR8D_EMPIRE
Scarlet V2 - #Project333Ti - http://www.bimmerforums.com/forum/sh...(-Project333Ti)
What fuel? What CR? How much ignition timing where you at with the misfire?
WOT
12cm housing, stock compression, E85 and around 14 or 15*
I'm no expert, but I would throw some more timing at it and think about getting a bigger turbo.
WOT
Eh, I like how the car drives with this turbo so I just want to make what this turbo can do and leave it at that. Just gotta figure out the misfire under higher boost. I just switched out all 6 coils with brand new ones and went a step colder on spark plugs. I don't really know if that fixed it or not yet.
I've turned it up to 15 PSI now and no spark issues so far. Going to be hitting up the dyno again soon and shooting for at least 400whp.
Any chance that 21 year old 202k mile valve springs are just old and weak and floating under boost at high RPM?
It should bolt well past 400. S256 is a comparable turbo to the HX35, and I'm on 8.5:1.....
1989 E30 - M50B28 Turbo - ZF 8 Speed
Put more then 15 degrees into it. Creep up on it and check the plugs. Get them to all look the same (with individual cylinder trimming) and then start going up on timing.
328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
9.20 at 150 on 22psi
You can run ethanol pretty fat and not lose power assuming you can light it off. If your already running into break up issues, running it fat wont help you with that. On above 1000whp, i target 11.2 until we are looking for every ounce of power.
Without wanting to sound like I know better (because I'm damned sure you have 100 times more experience than me) but on the dyno we found power to be made with E85 by not running rich. That said, it was dipping below 11. I sit around 11.8:1 to 12:1, but I'm hardly pushing shxt with 8.5:1 comp and 18psi.....
FWIW, I'm still running stock old coils with a 0.9mm gap - NGK Iridium. I don't recall right now what the dwell is set to.
I gapped mine at .022, did I go too far? I had the NGK Iridiums but it didn't like them even at 5 PSI. That was before switching the coils.
Is there really any benefit to running e85 fat since it cools so well?
