Has anyone had any experience with a code 216 : "Signal Lambda probe after-Kat Bank 2 not any signal"?
Does this mean that one of my sensors has finally gone kaput after almost 150,000 miles? I reset the code 2 days ago, and it returned today.
Many thanks in advance.
2001 Z3 3.0i -Oxford Green/Sandbeige
2016 428xi -Estoril Blue II/Black
2018 430iC- Estoril Blue II/Black
2018 330it - Melbourne Red/Venetian Beige/Black
That would be my guess. If you change the post-cat sensors, and the code comes back, it's likely that your cats are shot.
Have you ever changed the pre-cat sensors?
Yep that's a pretty straight up code for "no signal", don't think there's anything surprising there. Should be easy fix. Thats an emissions related failure so depending on your state it would normally be automatic fail...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Ed CT
1998 528i
5-Speed
Aspen Silver
Aubergine Leather
I'd do them all at once at that mileage. Reset adaptations.
There's absolutely no DIYs on this for the 99-00 528i post cat sensors. I hope it's not as heinous as what I see for the e46s. Can anyone steer me in the right direction? The pre cat ones are easy enough, but no info on the post cats!
Errrm one of the most self explanatory jobs really... It's basically 'Wrench them off, which will suck" then "work the wire out back to the connector, and unplug...".
Definitely wrenching them off WILL suck by the way, if they are the originals.
However... tips:
1. soak in penetrating juice overnight/over days (try soaking, then running the car a very short time to just warm them up and get it to soak in more, then repeat... not too hot so it burns the oil off but warm enough to encourage soaking-in. you might repeat that a couple of cycles / overnight)
2. be REALLY careful on your first try and have good O2 sensor wrench for it, if they strip the heads it will suck more.
3. have a propane torch handy to heat them up if that doesn't work
4. be gentle w/ the connectors, the plastic latching clips are likely all heat-fatigued also, with luck they don't break when you pop them off, but...
There are a couple styles of "O2 sensor wrenches". The 'full deep socket with a cutout' is great but sometimes there isn't clearance for it. No idea about the M52TU. There's also the "crowsfoot-ring-with-a-slot" style which tends to fit in tighter places.
Here's a Pelican DIY, if you didn't find this already. They warn about silicone penetrating oil, I'm not so sure I'd fret that too much as long as you dont get a crapload inside the exhaust and don't touch the new sensor tips to any of it (for instance, you could hose down the penetrating oil with brakeclean before you get near the bungs with the clean new shiny ones).
https://www.pelicanparts.com/BMW/tec...eplacement.htm
2003 M3CicM6 TiAg
Former:
Thanks for the tips. I was just wondering where the connectors were. Probably have to snake them up to behind the engine, which I'm not looking forward to. The car was an SC car all it's life so hopefully lack of road salts helped keep the undercarriage clean.
I dunno for your car, but on the E46 they aren't bad. They are tucked into various wiring retaining fittings under the car, pretty obvious, the pigtail on the new one will show you that its gonna be close by.
Now on my M3 I had to relocate the post-cats when I changed the cat config to further back under the car, so I had to indeed slice the harness wrap back and pull down more length, but, in your case none of that will be the case... should be easy.
2003 M3CicM6 TiAg
Former:
Full deep socket works best on the pre-cat sensors but you'll need the offset wrench version for the post cats. For each post cat sensor, I cut the cable at the sensor itself then used it as a fish to pull the new cable up (also makes it easier to remove the sensor and you can't mix up connector locations on the top of the engine either). You will need to disconnect the cables from brackets that are easy to see/reach once you're under the car. The brackets may be corroded and need replacing also.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
I have done both early and late, both pre and post, I6's with a combo end wrench. But I'm nuts. For late, pre cat sensors you really should use one of the crows foot flare nut sockets. For lack of a better term. I even bought one for the second time.
98 328is
02 525ita
80 528i
81 528ia
and decades of owning and driving BMWs
2003 M3CicM6 TiAg
Former:
I bought the crows foot, but not flare? Is that the one that wiggles around on the end of the extension? Oh and I was able to grab a snapshot of the O2(s)
No, 'flare' means it goes beyond 180 degrees, and only has a small slot in one 'facet' of the wrench. A traditional 'open ended' wrench is missing 2 facets of the wrench, a flare nut only has a small slot in one facet. A flare nut wrench lets you slip it over a wire or tube, but still get a grip on all the corners of the nut... FAR less likely to strip the corners of the head. Used most often for brake lines.
The GOOD crow's foot O2 wrench is indeed, both a Crow's Foot (extends out off of the ratchet point, instead of rotating around it) AND a Flare (grips all corners, small slot in one face to slip over the wire).
Last edited by geargrinder; 05-12-2018 at 10:09 AM. Reason: typotard that sentence made no sense
2003 M3CicM6 TiAg
Former:
Cool then. This is what I bought, should be delivered today.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also installed lift yesterday... Good times ahead.
NICE! I hate people who have lifts.
2003 M3CicM6 TiAg
Former:
