Results 1 to 4 of 4
Thread: altenator and battery issue
    Aug 2011
    woodbridge,nj
    2002 330ci con.&75 MGB
    Hello, looking for advise. 2002 330CI convert. Driving about 50mph and hear pop noise, battery light comes on and headlight indicator is red. Pull over and shut off. Belts are intact, restart and belts are turning, warning lights still on.Drove home got my meter out and read 10.5VDC with car running. Shut off motor and checked battery voltage and is 11.4VDC. Daytime running lights are out but my headlamps will work. Going to charge the battery and check more tomorrow in the daylight. Any input would be appreciated.
    Rich B
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    You need to replace the alternator or at least the voltage regulator. If the battery is old you should consider that too.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Be advised BMW sourced alternators for the E46 from Bosch and from Valeo, a French company. They are not interchangeable without major work. However, I’m betting it’s a Bosch 120amp alternator. If it is, I recommend you install a rebuilt alternator that’s been rebuilt by Bosch. It’ll come in a black box. It should come with a cooling duct at the rear. Don’t waste your time and money on a Duralast or other aftermarket alternator. They don’t last.
    Aug 2011
    woodbridge,nj
    thanks, I got a rebuilt Bosh but couldn't get the nut loose for the fan and shroud removal. Found someone who will do it .
  1. Subwoofer and battery issues
    By realcalidairy in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 09-05-2017, 04:48 PM
  2. Idle and battery issues after CCV replacement
    By RaulsE30 in forum 1999 - 2006 (E46)
    Last Post: 08-03-2016, 05:59 PM
  3. Electrical and Battery issues 2005 BMW 525i
    By kthrall in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-16-2013, 05:38 PM
  4. Trickle charger and battery Issue
    By Raymondlee177 in forum 2004-2010 (E60,E61)
    Last Post: 12-09-2010, 09:30 PM
  5. Lights and Battery issue
    By NolaSicilian in forum 1995 - 2001 (E38)
    Last Post: 06-03-2009, 02:22 PM
