Results 1 to 2 of 2
Thread: Loose Ignition Coil ground shorts out DME?
    May 2018
    florida
    BMW x3
    I had a valve cover gasket repair on my 2006 X3.
    and the shop left the ground wire to ignition coils 4, 5 and 6 loose.
    Car had a bad miss and after rehooking the ground, cylinder 4 still not firing.
    Replaced plugs, tested for bad coil, tested for short to ground, bad wire etc.
    Computer scan by Bmw tech indicates DME (computer) is damaged. Is it likely a bad ground connection can short out the computer?
    I would say it's definitely possible. If they were the ones that left the wire loose, then they should be on the hook for the repair.
  1. E34 ignition coil grounding?
    By TryAgain in forum 1988 - 1996 (E34)
    Last Post: 11-17-2008, 10:56 PM
  2. # of Ignition coil ground wires
    By nick95325ic in forum 1991 - 1999 (E36)
    Last Post: 07-16-2008, 01:10 AM
  3. Ignition Coil ground strap placement?????
    By speedcrazy1532 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-05-2008, 02:31 AM
  4. Doh. Where do ignition coil ground wires go?
    By Ahheck01 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-18-2006, 04:08 AM
  5. Quick ignition coil ground question?
    By zrozof in forum 1992 - 1999 M3 (E36)
    Last Post: 02-06-2006, 11:25 PM
