Howdy,
I'm currently working on making an MS3Pro to M50TU adapter in an E34. I purchased the MS3Pro from a member here along with a gutted MS41 case with the 88-pin.
While I was mocking it up, I took the stock DME out of the car and tried to plug the gutted case in, but it looks like the connector from the car doesn't perfectly match up with the gutted case's. I've attached pictures of the two DMEs I have next to each other. I've circled the slight difference in red.
Is this able to be modified to fit alright or should I just go searching for a 413 plug? I was under the impression that all 88-pins should fit.
Thanks in advance!
For anyone else reading, I just used a utility knife to cut the relevant bits of plastic that interfere with the connector fitting. I also reused one piece by super gluing it in where the 413 DME has it, but it wasn't completely necessary.
Case in point, just cut the interferences off.
