Results 1 to 7 of 7
Thread: Fixing My Rotted Out Rear Hatch
    Plymouth, MI
    '97 Chevy Camaro, '89 Merkur XR4Ti
    Now,I am thinking of rerouting my wire loom so I won't have to drill a hole to newly welded patch..... I think having a wire enter through a main water flow channel is just a dumb idea in the first place.. Anyone have any good ideas?
    2001 BMW 525iT - Stock Daily Driver and Tow Rig
    2001.5 Audi S4 - Stage 3 Bi Turbo
    My Blog of Cars, Guns, Computers, and other hobbies
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Yeah, the hatch is a weak point. So much crap gets caught there. If you go that route, show us what you did please.
    Aug 2016
    Indy
    1999 BMW 528i Touring
    Quote Originally Posted by CPHES View Post
    I second that request. I have two large bubbled areas as the OP and have them "patched" (covered with clear gorilla tape). A friend of mine familiar with auto body and painting said the only real solution is to do what the OP is doing (cut & weld).
    Isn't there also a known culprit for this issue? Something about a drain plug or something that clogs?
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Dirt and grime pool up in there, underneath the plastic trim. Over time, as rains come, and go, water pools up in there with the dirt, it stays wet, and eventually the clear coat lets go, now water attacks the base coat, gets thru, and rust starts to form. This is why one must keep his or her E39 Touring clean, if you keep it clean, not so much dirt builds up in there. I also try to blow a large amount of compressed air in there, Boggs sides, it blows out a lot of moisture, every time I do. Been doing this for over 8 years, I don’t have any rust in the tailgate.
    The last time I had the trim off. The next time I do it, I will be repainting the whole car, when it take the trim off, I will coat the whole area under the trim with POR15, or 3M urethane primer and I will not have to worry about that particular known rust zone in the future. For now, I always try to remember to blast the area free of moisture whenever it rains, as much as possible.
    Nov 2016
    NY
    Haha - the OP is in Michigan, and my car spent 11 years in Boston - Virginia has nothing in comparison. Yes, there are lots of nooks and crannies to get stuff stuck in. Frequent cleaning helps. I got a clean used gate from a southern car. Now it has to go on....
    Plymouth, MI
    So, last night, I finished all the welds (Both sides were rotted out and the side on the passenger side was rotted out also so, total of 3 weld patches).
    I'm trying to brainstorm some ideas for the wiring.
    e61 Touring has the wiring hole more up the rain channel. Which is an improvement from e39.
    http://tcbf62.blogspot.com/2016/01/b...te-wiring.html
    Route it underneath the hatch like VW golf?
    https://www.stuartdalby.co.uk/vwgolf...ires/index.php
    Move it all on the interior of the car like this?
    http://forums.turbobricks.com/showthread.php?t=272711
    Some wire sleeves to protect the wires.
    https://www.cabletiesandmore.com/hea...y-sleeving.php
    Nov 2016
    NY
    Did you dump a lot of pod—5 back there? It’s very hard to get all the rot out
  1. How the hell do I fix my rear camber problem?
    By cosmos95m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2006, 09:36 AM
  2. Fixed my purple rear shelf
    By epj3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2006, 10:10 PM
  3. My drivers side rear squeaks everytime I get out of the car..
    By BMWnoob in forum 2001 - 2006 M3 (E46)
    Last Post: 01-25-2006, 10:57 PM
  4. Broke my passenger side rear vw mirror off, how to fix??
    By DJ_Vyb in forum 1992 - 1999 M3 (E36)
    Last Post: 10-05-2005, 06:52 PM
  5. My baby got rear-ended. Need help with getting her fixed.
    By Persian BMW in forum Middle Atlantic - US
    Last Post: 11-27-2004, 03:45 AM
