Bavarian Soundwerks
Results 1 to 4 of 4
Thread: Stuttering Bluetooth
    May 2010
    Redwood City, CA, USA
    2003 330i ZHP; 2012 M3
    Question Stuttering Bluetooth
    So I just bought a 2012 M3 with Nav package earlier this week. It’s been a dream come true, literally.
    I have one issue though. The audio periodically stutters when using Bluetooth. Has anyone experienced this? I’m trying to search google/forums but so far I haven’t had much luck with a solution.
    BMW CCA Member 440285 - Golden Gate Chapter
    2003 Imolarot 330i ZHP
    2008 Z4 M Roadster
    2012 Dinan 4.6L M3 ZCP
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Background: I think most BT systems buffer data upon connection. That way any slight/short interruptions in the flow of data are unheard by the listener.
    Hypothesis: the buffer in the head unit is occasionally being “emptied,” which results in intermittent loss of sound.
    What device are you using as the source of the audio data? Smartphone?
    How old is that device?
    May 2010
    Thanks MarcoZandrini but I think I found the solution!
    Since it got worse when I was moving I had a hunch it was a loose connection somewhere. After some research I found that the bluetooth antenna is in the driver footwell. I took a look at it and found that the connector wasn't snapped in. I pushed it all the way in and now (knock on wood) it seems to work!
    2008 Z4 M Roadster
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Great job!
  1. Does a fouled up 02 sensor cause stuttering
    By Euro77 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-25-2003, 03:49 PM
  2. My 1999 Dinan E36 M3 stutters when cold
    By Dinanify in forum Forced Induction
    Last Post: 01-17-2003, 06:59 AM
  3. 1999 e36 m3 stutters while cold
    By Dinanify in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-16-2003, 10:21 AM
  4. Need Help!!! Car stuttering above 5000rpm!
    By LUIS in forum Forced Induction
    Last Post: 11-21-2002, 02:11 PM
  5. Bluetooth Technology
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-18-2002, 12:38 AM
