Results 1 to 11 of 11
Thread: Rim selection
    Mar 2018
    Watsonville,ca
    911 , f 350
    Rim selection
    Just purchased 1997 328i . Stock rims on the car are 15" . From what I read 17 s will fit this car . This will be a track car that will be driven to track . What would be best size rim for the track . Any thoughts on rim size and or tire choice would be greatly appreciated.
    Thanks robert
    Jul 2006
    Raleigh, NC
    E36 Track Rat, E46 M3 DD
    17x8.5 seems to be a common E36 track car rim, with Kosei being common.
    Mar 2018
    Watsonville,ca
    911 , f 350
    Wondering if I use the 17 x 8.5 is there other modifications that will need to be made .....fenders etc . I am starting from scratch trying to be prepared so I make sure I get it right the first time . As I am full time employed I plan to use others to do the up front work . Want to be educated so I have a clue before moving forward , thanks for any suggestions
    robert
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    https://www.tirerack.com/wheels/Whee...int&tab=wheels
    I run these square on my e36 and can get 255 Toyo RR's under there with coils and a 5mm spacer up front
    Like them so much I have two sets
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    Jul 2011
    West Seattle/ Pullman, WA
    98 M3 Cosmos
    17x9 et42 Apex ARC-8 is a pretty common setup too. You'll need a spacer in the front to clear the spring.
    Mar 2018
    Watsonville,ca
    911 , f 350
    Thanks for info , will be purchasing something early next week . Car is going in for some suspension mods and tires and wheels
    Sep 2013
    Perth, Australia
    2011 BMW 135i
    Quote Originally Posted by NorthWestM View Post
    That's what I run, with a 12mm spacer on the front and 245/40/17 Advan A050s.
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    D-Force LTW5s and Apex ARC-8s in 17x9 ET35 to ET42 are two of our more popular wheels for track guys. They'll let you run a lot of meat, but be aware as NorthWestM said spacers are needed on most setups for spring/coil/shock clearance.
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
    Nov 2012
    Those are excellent wheels. I would supplement my choice with the additional $$$ you will still have in your pocket for other mods you might want. My car is strictly D/E so at some point I have to compensate my "wannabe" with the reality that I might not get the benefit of a wheels the is a few ounces lighter. Do the math on what works best for you and enjoy your build and getting out on the track!
    Mar 2018
    Watsonville,ca
    911 , f 350
    Help me out here . I think my head is going to explode.....so many decisions, so many choices . I had finally decided on a tire and tried to order from multiple sources and .......it's either back ordered or not available at this time . Ugh ?
    The tire I was interested in was Federal 595 rsrr 235/40 17 no luck so help a guy out . What's next . I will be driving these to the track 30 miles , but this is not a car that will be driven as a daily driver .
    The rims I am going with are T r motor sport C2 s
    I am almost there , car is in shop . Suspension, brakes , mounts and a bunch of other stuff that is adding up quick need tires I can actually buy , that is before my head explodes
    thank you all
    robert
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    Those RSRRs in that size are in stock on Amazon.com. I used a set, in that size, on your chassis last season, and I liked them, ESPECIALLY for the money. But I hope it's dry in Watsonville, because once the tread wears down a bit they are a handful in the rain if you try to drive to the track. Once at the track, I thought they were actually just fine as rain tires, as long as I didn't try to steer or accelerate in any puddles or streams.
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
  1. Help needed with 328i Cab wheels/rims selection
    By noeddeon in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-15-2012, 03:47 PM
  2. Need some rim selection advice (looking for 5-spokes)
    By mike87 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 12-18-2009, 07:24 PM
  3. Replies: 2
    Last Post: 08-04-2005, 04:53 PM
  4. rim selection
    By johnfastm3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-07-2004, 03:04 AM
  5. New Tire and Rim Selection
    By SvenOdin in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-28-2002, 10:55 PM
