Results 1 to 8 of 8
Thread: Non costant power
    Nov 2009
    italy
    325i e36
    Non costant power
    Hello, i have m50b25 (2800 cc) 84mm x 84 mm non vanos
    -cr 8:1 wiseco pistons eagle rods
    -aem intank 300 lph fuel pump
    -gt35 turbo exhaust ar .68 intake ar .70
    -525 cc injector
    -kdata megasquirt
    -stock head and cam
    -mls cmetic head gasket with arp head stud
    -boost is 1.25 1.3 bar
    now the trouble:
    i dynoed 530-540 hp first 3 4 dyno with afr 11.5 and egt ok no more than 900 920 c° max
    now after 3 4 launch on dyno, without mod ecu i get 420 430 hp, no boost leak
    Has anyone had similar experience?
    Log of parameter is ok, afr is still 11.5-11.6 but get 100 hp less
    I had stock valve on exhaust, can i have trouble with exhaust valve? i need nimonic?
    i am lost
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    "without mod ecu"
    What does this mean? Also, are you able to log timing?
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by leomarcus View Post
    i am lost
    As are we... you didn't provide one single thing that could let us understand what is going on to help you.
    You're basically asking us to guess.
    Post the data log from your dyno runs from start to finish, identifying the ones run with the power loss, and post your dyno sheets along with any other data (AFR, BOOST, etc).
    That would be a start.
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    If it's .68AR on same dyno, same temp day, same gear, same fuel, etc. it's possible the IC heat soaked and your timing was reduced. High intake temps cause me to lose 80hp on summer days too.
    Nov 2009
    italy
    325i e36
    I found little leak in exhaust flange between manifold and turbo but boost is still ok
    .ar68 is bad?
    Oct 2016
    Philadelphia, PA
    E36 2JZ
    Not bad for response. It'll run out of steam faster. Just know you'll lose some power up top. Especially on hot days and back to back pulls
    Nov 2009
    italy
    325i e36
    I think is something related to valve train
    Does anyone know if are there common problem relatin to boosted m50 with more than 500 hp?
    Valve..spring...hydraulic lifter cam are all stock
    Nov 2009
    italy
    325i e36
    Found leaks on exhaust manifold but turbo pressure is still 1.2.
    Exhaust manifold leak can lead so much performance?
  1. BMW 525TDS 2001 NON constant power loss
    By dominic1968 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-02-2009, 10:23 AM
  2. Pair of Dove Grey 99 M3 Non Heated/ Power Vader Front Seats in San Francisco $380
    By wrecked99m3 in forum Exterior Lighting & Body Parts
    Last Post: 10-01-2008, 12:25 AM
  3. e36 Non-heated power seats ~ Front driver and Passenger
    By jijacob in forum Exterior Lighting & Body Parts
    Last Post: 08-05-2007, 01:33 AM
  4. WTB-non Vader power seat motor!
    By undrh2o in forum BMW Parts Wanted
    Last Post: 12-25-2006, 09:04 AM
  5. FS stock non M power mirrors 4dr e36
    By Deadboltz in forum BMW Parts For Sale
    Last Post: 04-04-2005, 06:52 AM
