Results 1 to 10 of 10
Thread: How is all this rain water getting inside my E36 chassis?
    Aug 2009
    Metro DC
    79 323i, 94 325is, 13 M3
    I just had my first day of heavy rain driving in my stripped E36 chassis. I took on board water on both sides of the passenger compartment and the trunk. Where is all this stuff getting in?
    If God meant for man to motor-swap LS engines into track cars, He wouldn't have created Corvettes.
    Mar 2010
    Eagle Idaho
    M3, M3, 323is
    Sunroof drains might be clogged. Which will make it drain into the car. Or when you stripped the car you cut or broke the drain lines. hope this helps.
    Oct 2003
    Seattle
    99 M3
    Ya, most common reason is sunroof drains, however did you remove the trunk lid seal?
    Also these can get old and leak.
    Aug 2009
    Metro DC
    Thanks I’ll check those drains. Where do they start and end?
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    It would be immensely helpful to us internet guessers if you post a photo of the interior. "Stripped" means very different things to different people.
    Aug 2009
    Metro DC
    Ah! My bad. Let me see what I can come up with.
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    The tubes originate in the sunroof cassette and run down through the C-pillars, into the trunk area and out from there. If you pulled the tubes and didn't seal up the sunroof area, that's a really good place to start.
    Aug 2009
    Metro DC
    I checked it out, and all 4 sunroof tubes are still clamped up tight at each of the corners.
    Should I maybe pour water on the sunroof from the outside, and see if it starts turning up inside the cabin?
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    If took the car all the way down you could be sucking water in your floor drains....or actually have some rust holes down there.
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Get the hose out and let her run for a while until you can pinpoint where it is infiltrating.
  1. Cant stop water getting inside my m3
    By motley68 in forum 2001 - 2006 M3 (E46)
    Last Post: 02-11-2008, 07:03 PM
  2. Rain water getting in my 93 740i
    By Crescent535 in forum 1995 - 2001 (E38)
    Last Post: 01-01-2007, 10:56 PM
  3. Where is all this water coming from?
    By Z3Meister in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-25-2005, 01:59 AM
  4. How much do you think is all this worth???
    By LukeG in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-27-2004, 04:51 PM
