Hello. What's the difference between those two? I mean springs.
There's quite a bit of info out there. Try searching S704A vs S705A.
To recap... S704A (Sport Suspension) used lower springs, matching shocks and slightly larger diameter sway bars. S705A (Sport Suspension-II) to the best of my knowledge used excess M5 suspension components. I'm certain someone better informed will chime in soon...
James
I'm asking because my EDC springs are setting the car a bit too high and i don't know which one to buy, I or II.
Try this tread on this same questions. Appears to be a option package with interior, exterior, and suspension parts tweak.
http://www.bimmerfest.com/forums/sho...d.php?t=869188
Current Garage Highlights
2003 525iT TiSilver
2002 M5 TiSilver
Former Garage Highlights
2005 X5 4.8is
2004 325iTs (2x)
1973 Pantera L
1969 Road Runner 383
On what car are you trying to fit the springs?
Try a VIN decoder to see what suspension package your car came with. Consider contacting one of the reputable vendors to ask their opinion on what spring you need. Oh, by the way, why are you buying springs? They typically don't fail.
I have EDC. I'm buying because the car is too high.
Mtech ll springs are the same as M5’s, same valving on the shocks, and struts, the torsion bars are 25mm, same as the M5, I may be off on some of that, but it is what I remember when I was boning up on info on my Canadian spec 2001 540, it is actually a real deal M Sport 540.
Mtech 1 springs are softer, the struts and shock are more compliant, the torsion bars are 24mm front and rear. The regular suspensions..... eh, who cares.
Some have said the MII springs themselves are NOT exactly same as M5 and will result in ride height discrepancies / problems if you put them on a 540, which is their 'proof' that they aren't the same. There's threads on this from WAY back in the day.
I've always been skeptical about that. The front end weight difference of a 540 vs M5 has got to be very nearly insignificant. What, the extra weight of the ITB's and VANOS required a massively different spring rate? No.
Others have suggested however, there MAY be some perch differences between the M5 and regular 540 stuff, so perhaps the guys who whaaaah bout M5 suspension increasing ride height have mis-matched the M5 parts with the wrong perches or strut mounts or something.
Now. The M5 / MII spring rates STILL might be a tad different. I wouldn't doubt for a minute that BMW would have some teensy difference there (have seen it w/ VAG where they have a boatload of "why?!?!?" different spring color codes for one model of car...), and springs are hard to confirm as they don't carry PN's, but, all reports are the MII STRUTS are the same PN's as the M5.
In summary... Possibly the springs are a teensy different, but if so, they are interchangeable on the struts and given the similar weight of the cars, they can't be that different. The struts are for sure the same. But if you try to use the springs on a normal 540 strut, you likely have problems.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I'm not sure about the front but would have to agree with the grinder as far as the rears go. I had a cracked spring on my vanilla 540i and used a set of M5 rear springs and struts to get the old girl past its NYS inspection. The ride height stayed the same (crack in the spring was at the bottom of the spring) and to be honest although the springs were visibly different the ride and handling don't really seem different. Must be the changes were fairly subtle, at the rear of these anyway. The sway bar might be smaller on my 540i than an M sport or M5 and that would probably be noticeable in transitions. Perhaps that's where the big difference lies...
So are you guys saying in my '03 Sport with the Mtech II suspension that I have the M5 sway bars, or at least the M5 rear sway?
Your rear sway bar is not the M5 version. It's upgraded over a regular 540i but it's still not the M5 part (Mtech-I/Mtech-II 15mm vs. 16.5mm M5)
M5 front sway bar is 27mm while Mtech-I/Mtech-II is 25mm.
1999 S62 Powered 540i
2009 N54 335xi
Thanks. I'd always thought my sway bars weren't the same as the M5's. This confirms that...
'03 540i-6
153k mi; bought April ‘07 w/38k mi
Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
Guys whats with all the confusion?
This is the exact difference
Wheels
2003 M-Sport USA style 37 rims
01-02 M-Sport International style 66 rims
Springs
Same rears but shorter fronts at same spring rates because 540i front end is lighter
Shocks/Struts
Identical to M5
Swaybars
Same as 540i Sport, we don't get M5 sway bars at all
LSD
Only on M5, 6spds have 2.81 and 5 autos Steptronics have 3.15 same gear as M5 just open
2003 540iA M-Sport - VSM60IM/84MMTB+Flange/4"CAI+MAF DUDMD Tune, Alpina B10V8S TCU Tune, Spal EFC, Gutted Pre Cats, 88C Stat, Alum WPP, Metal Impeller WP, SAPD, M5 MMs, UUC Blk TMs, E53 X5 TABs, Bilstien B8's/Intrax Springs,
I've got S705 option ans I'm thinking of replacing the struts.
Anyone knows what's the right kit for that?
I saw a kit for s704 on fcpeuro but not for s704
5
FCP does not have it as part of a kit, but it does have the struts separately.
BMW Strut Assembly - Genuine BMW 31312229612 | FCP Euro
Pretty steep for a strut but what do you expect for an M5 piece. Even the S704 as Genuine BMW is up there at >$400. At least that you can get the OE equivalent Sachs w/o BMW logo for <$200.
Appropriate Bilstein have a reputation of being notably harsher riding than stock BMW Strut Assembly - Bilstein B8 Performance Plus 35-114093 | FCP Euro
So, what I have as a replacement for when the time allows is IMO an excellent compromise.
BMW Strut Assembly - Koni Sport 87411372Sport | FCP Euro
I've had Koni adjustables on an early ex e36 325 and the non adjustable STRT version on the current 318ti. The adjustable will allow you to tune them to your preference. Soft for crappy pavement and tight for canyon carving.
Hope this helps
Hang up & Drive!
Jerry .. 85 Toyo MR2 140K .. ( 20V wiring gremlins *grrrr* )
Björn .. 03 BMW 540i///M 148K .. ( beat up allstar *oof* )
Gerta .. 03 BMW 540iT&A 151K .. ( chain guide triage *shakes head* )
Franz .. 96 BMW 318ti 207k .. ( the new, new daily *GRIN* )
Wendy .. 20 Honda Refrigerator 28k .. ( for the wife and kids, has flappy paddles? *squint* )
Resistance was Futile...
"Now, it takes me three months just to fix a door lock because .. crying babies" - rammstein
Thank you, these are indeed very expensive. 2k just for the struts hehe...who's the original manufacturer for them, Sachs? Do you happen to have a link to Sachs?
I like original bmw ride, nice and soft, perfect for canada. Roads are bad here in canada, bumps everywhere...
I've had Bilstein b6 on my 528i.
Found them very harsh. Not sure what version is the softest, b12?
If going with these koni, I suppose these would be for the rear?
https://www.fcpeuro.com/products/bmw...-82401156sport
Wow rear oem struts for S705 suspension are $800 each
https://www.fcpeuro.com/products/bmw...39-33522229126
my car has the m1 (s704a) suspension from factory but due to aging I had to replace struts a couple years ago and I replaced them with m2 ones. car has been fine except the rear. it looks a bit high. now one of my customers want to swap his e39 m5's suspension to another brand and I have the chance to buy his springs. it's an 2003 m5 so it has probably m2 springs on it, I'll just install them in my car and see how it looks.
