Results 1 to 9 of 9
Thread: 03 325i square 02 sensor plugs?
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    I have apparently the oddball manufacture 03 325i that has square 02 sensor plugs for precat sensors. The problem is I got my full set of 02 sensors months ago and didnt bother to check if the plugs matched and obviously cant return them. I simply havent ever seen square plugs on these before. Is it ok to splice them in, or are they not compatible? Are the post cat sensors the same scenario as well? Thanks for any input ahead of time gentleman.
    -Oakdizzle
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Are you the original owner of the car? Does the car have the M56 engine? Go to bimmer.work and enter the last 7 characters if thr car’s VIN. That’ll tell you if the car has the M56 engine. That engine is part of the super low emissions vehicle package. The fuel pump is part of the fuel tank so it can’t be replaced separately. If it’s an M54 engine, which the vast majority of E46s have, someone replaced the normal sensors with some weird sensors.
    If the engine is an M54, you need to buy Bosch (and only Bosch) direct replacement sensors. Label the connectors which reside under the black plastic cover on the top of the engine.
    I googled the part # for the sensor. All of the pictures from reliable sites that specialize in bimmer parts show a typical sensor with 6 lands. That is, those sensors in your car are not Bosch sensors. Here’s an example:
    https://www.turnermotorsport.com/p-3...probe-e46-m56/.
    Nov 2013
    Oneida, NY
    It's an m54 for sure. I replaced the engine with bad crank bearings when I bought the car for a lower mileage well working one. I noticed while looking at several e46 in junkyards, the m52 e46 have round 02 sensor plugs. 04 and up have round sensor plugs.. my car... does not. Why must it be bosch?
    Nov 2013
    Oneida, NY
    -Oakdizzle
    Nov 2013
    Oneida, NY
    This is part of a converter replacement. 1 converter simply fell apart when I replaced the engine awhile ago. Since then the 02 codes have come for both pre and post. I figured of just get cats and 02 sensors and throw it all in at once.
    -Oakdizzle
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Square connector with 6 wires is wide band o2 or AFR sensor used in later models. Early cars had standard o2 sensors with 4 wires and a round plug.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Was the harness replaced at any time to your knowledge? I've never seen the wiring going to the coils exposed.
    Nov 2013
    Oneida, NY
    I don't have any issues with misfires or coils, so it wouldn't matter.
    -Oakdizzle
    Aug 2014
    Lawrence Kansas
    Couldnt care less of you're having misfires. Was asking in an attempt to find if the engine harness has ever been replaced.
  1. 02 sensor plug question
    By MThrizze in forum 1992 - 1999 M3 (E36)
    Last Post: 07-11-2010, 08:07 AM
  2. 535i 02 sensor plug location? Against my better judgement...
    By sfgearhead in forum 1988 - 1996 (E34)
    Last Post: 12-14-2008, 10:47 AM
  3. primary 02 sensor plugs?
    By weaksauce in forum 1992 - 1999 M3 (E36)
    Last Post: 02-12-2008, 10:20 PM
  4. 02 sensor plugs + check engine light
    By 3DGE95Ti in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-17-2008, 01:33 AM
  5. Need 02 sensor plug
    By ceegeezM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2003, 03:32 PM
