Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 58
Thread: New with 1995 E31 V8 6-spd
  1. #26
    Nov 2009
    Las Vegas, NV
    95 840ci 6sp,00 750iLV12
    I haven't either, but this is just part of what I have to deal with now...amongst other wierd things going on with the car. Finally put Hyper parts in passenger door. Now both are ready for many years to come.
    Sent from my SPH-L720 using Tapatalk
  2. #27
    May 2013
    Stamford, CT
    1991 BMW 850i
    That is a little strange (I haven't seen a ton of 8ers, but never one with the buttons there). Also, I don't think the car came with cup holders (aside from the thing on the glove box door). None the less, nice looking 8. And a 6 speed to boot!
    My Cars - 1991 BMW 850i - mine for fun, 1993 Saab 900c - mine for fun, 2008 Lexus is250 - my daily driver, 2003 Dodge Durango - my wife's, 1994 Acura Legend - gave it to kid
  3. #28
    Nov 2009
    Las Vegas, NV
    Thanks. Yes, cup holders are nice. I am having a throttle issue currently. Initial start of the day throttle is perfect. Go to work friend's house or to the store gas station Etc, app on restart no throttle for 2 to 5 minutes then all is perfect.
  4. #29
    Jun 2010
    Hyperworld
    '97 840CI
    Quote Originally Posted by uinvyme View Post
    ...no throttle...
    An imprecise description, since we are dealing with a mechanical cable throttle.
    If you are having trouble coming out of idle then go after the TPS as it may be conspiring with the IAV to undo your initial input.
    How about some more pics of that nav panel thingy, above the half-MID.
  5. #30
    Nov 2009
    Las Vegas, NV
    I didn't review this before I posted. Talk to text did not say upon restart (app). I will upload more photos later. But yes, no throttle... 1st cold start of the day, no problem. 2nd or 3rd after driving will make me wait 2 to 5 mins before it gives me throttle. It starts fine and idles fine. I was thinking voltage since new amp and sub got replaced before this started. Also swapped Idle Control Valve for used when mine was acting up. I have new ICV just waiting for install. I have 2 TPS? I know v12 has only one. Thanks again for the handle fix for both doors.
  6. #31
    Jun 2010
    Hyperworld
    '97 840CI
    ...no throttle...
    Still having trouble with those two words.
    Do we pop the hood to see whether it has left the engine bay?
    On the 840, one throttle connected by cable, if it's still there also.
    One TPS, hopefully telling the ECU that you ARE or are NOT at an idle position, requiring or not requiring intervention by the perfectly functioning IAV/ICV.
  7. #32
    Nov 2009
    Las Vegas, NV
    Ok, I'll check. I'm quite sure that the idle cable is still connected, since I regain full functionality of throttle after 2 to 5mins.
  8. #33
    Nov 2009
    Las Vegas, NV
    Center console
  9. #34
    Tampa, FL
    '93 850Ci, '07 X5 4.8
    I started feeling the slip pulling off and it was getting worse. I believe cost was in the neighborhood of $2K but I (purposely) forgot. I went aftermarket (IIR UUC Stage II) one of my clients is a Euro repair shop so I got a break on the work... we did the slave cylinder too. Think that was the first thing I ordered from Gault ..or was it the fuel pump...
  10. #35
    Nov 2009
    Las Vegas, NV
    Are you saying that you went aftermarket on the clutch and flywheel. I have the 840ci, so I hope I'm correct in thinking that my clutch and flywheel is different than the 850? I have the UUC short shifter, just waiting to be installed. Heard it's best to do during clutch replacement. Thanks for your comments and reply
  11. #36
    tvjake2's Avatar
    tvjake2 is offline SoCalEights - CA BMW CCA Member
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    This is pretty neat with all the work that's been accomplished. 'Should be a good car going forward...after fixing the clutch. Send me a PM with your info and I'll add you to SoCalEights. We have some members in Lost Wages. Then you can also join the BMW E31 Chapter online.
  12. #37
    Nov 2009
    Las Vegas, NV
    Quote Originally Posted by tvjake2 View Post
    sent you a PM, Thanks for the support. I need all I can get right now. Window tinters had to retint the car twice now. Am I too anal or too picky?
  13. #38
    Nov 2009
    Las Vegas, NV
    http://store.uucmotorwerks.com/oe-si...40i-p1286.aspx
    http://store.uucmotorwerks.com/ultim...540i-p355.aspx
    These are my choices for clutch replacement
  14. #39
    Tampa, FL
    Yeah ... totally avoided the dealer. They have a bad habit of marking up parts for my car 500% ...
    Knowing me.. I'll be doing it again at some point... sometimes I like to "feather" the clutch ;-)
  15. #40
    Nov 2009
    Las Vegas, NV
    I'm thinking about going for the 850csi option. What do you all think? Anyone have or know of a good Indy shop in Vegas
  16. #41
    tvjake2's Avatar
    Oct 2012
    Glendale, CA
    '97 840Ci, 1980 308
    PM Forum member "Major Cheese" he lives there.
  17. #42
    Nov 2009
    Las Vegas, NV
  18. #43
    Nov 2009
    Las Vegas, NV
    Part of my 99 challenges/questions... Is there a difference in the center consoles of the 850 6 speed and the 840ci automatic? My gearshifter and boot don't quite sit in correctly. Or do I just need to order the correct boot and shifter with frame off course.20180515_193144.jpg20180515_204233.jpg20180515_204220.jpg20180515_193200.jpgI saw a picture of another 6 speed conversion that looked righteous,6speed shifter.JPGmine doesn't look this good. Please advise...
  19. #44
    Orange County, CA
    840Ci|725tds|Alpina B7
    As far as the shifter area is concerned, every E31 console is the same, and any of them can be converted from auto to manual without changing that part.
    I did not replace mine when I did the swap:
    https://www.bimmerforums.com/forum/s...i-6-speed-swap
  20. #45
    Nov 2009
    Las Vegas, NV
    Ok, so, maybe I have the wrong shifter boot and frame. Because mine doesn't sit correctly in the pocket. Thx for the insight
  21. #46
    Orange County, CA
    No problem. Judging by the "craftsmanship" on your car by its previous owner, I would bet that the $200 shift knob/boot combo that the manual E31s came with was out of budget, so he just put whatever in it.
  22. #47
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    Quote Originally Posted by olinjohnston View Post
    Maybe. Then again, I've seen CSi's with both versions of the shift boot (one sits 'in' the console, one sits 'on' the console), and fairly certain that both were 100% original. Obviously the boots were different, since as olinjohnson says the consoles are all the same. Realoem shows different shift boot part numbers for the wood console and the plastic console, as well as a couple of discontinued part numbers for both, so there may be two styles.
    Mike Barrett
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
  23. #48
    Nov 2009
    Las Vegas, NV
    Thx guys, I will have the clutch installed next week whilst I'm out of town. Will have them also put in UUC Evo short shifter. I'll order the boot and frame from the dealer using part numbers that you all suggest. I would assume that the boots are different for 6 speed vs the automatic?
  24. #49
    Orange County, CA
    Quote Originally Posted by mbarrett635 View Post
    Mike Barrett
    Yes, there were both versions, but none look like what he has, and they are all one piece.
  25. #50
    Mar 2006
    Harrisburg, PA, USA
    I thought his was also, then I went back and realized I had been looking at your picture, not his. LOL. Sorry.
    Mike Barrett
    Mike Barrett
  1. New Owner - 1995 318 Ti with Drive Train Issues
    By AnuketTi in forum Hatchback Haven
    Last Post: 05-18-2014, 10:16 PM
  2. E31 V8 Radiator Brand New
    By jeffcfp1 in forum Parts for Sale
    Last Post: 01-11-2012, 12:30 AM
  3. E39 Brand new air mass meter for 540/740/x5 with 4.4l v8
    By deuceforty in forum Engines, Performance Parts & Software
    Last Post: 11-28-2011, 05:46 PM
  4. Check it out, new 2010 X5 Gets A Very M3 Looking Nose To Go With The TT V8
    By wohho in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-30-2008, 10:13 PM
  5. New BMW X6 with twin turbo V8
    By GTV6 in forum Forced Induction
    Last Post: 12-18-2007, 04:23 PM
