Page 2 of 2 FirstFirst 12
Results 26 to 27 of 27
Thread: different power steering fluid with SLS?
  1. #26
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    What was in there BEFORE you dumped more of something in?
    RED = ATF (Brown is old ATF)
    Green = CHF-11
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  2. #27
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Updated DIY for the correct 540 application the OP owns
    The flush process is pull off the line from the pump to the reservoir (RETURN LINE) and stick it in a gal pail/container. top off the reservoir with the correct fluid (ATF or CHF-11) and start the car. With a competent helper turn the wheel L/R lock to lock while keeping the fluid level at more than 60% full, slow is better. No need to race the engine, idle will do it all. If required you can add in a extension to the line with Home Deport brass hose union of the same size to make it easier to reach the collection bucket. Flush the system with approx 2.0 Qts which should be enough to clean and refill the system.
    Install the new lines and new Reservoir, use the pinch type of clamps, top off with fluid, start check for leaks, turn wheel lock to lock 5-6 times, Top off to correct level, road test, recheck for leaks and enjoy the greater road feel and reduced noise levels from the P/S system. NOTE: Replace the little rubber bumpers under the reservoir mount points if torn/ripped/missing.
    TIPS: When removing the bolt from the cooler make sure you use WD-40 on the bolt and mount, loosing it as there is no need to pull the bracket off as there is a slot for the return hose to slip off. REPLACE the O ring with new on the replacement hose, pivot the bracket back in place up right, and tighten (NO, DO NOT TORQUE until YIELD). If the bolt will not move - DON'T FORCE IT. Add some WD-40, tighten and loosen until it releases. If you strip it, you will be buying a cooler too (PITA install). Good luck!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  1. FS: E34 M5 power steering pump with SLS
    By 4heid in forum E34 Classifieds (closing soon)
    Last Post: 02-25-2016, 01:48 PM
  2. power steering issues with full fluid
    By nickhx2 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-28-2012, 01:10 AM
  3. Power steering fluid type different
    By jasons735 in forum 1988 - 1994 (E32)
    Last Post: 06-12-2012, 10:56 AM
  4. Replies: 13
    Last Post: 02-09-2008, 05:02 PM
  5. Dad topped power steering fluid off with non ATF?
    By Garrett M in forum 1992 - 1999 M3 (E36)
    Last Post: 04-10-2007, 08:39 PM
