Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 80
Thread: CCV questions?
  1. #26
    Jun 2013
    Durham, Ontario, Canada
    04 330Ci
    What is your opinion on the viton or flurosilicone o-ring for the kit darin? is it worth the extra 0.30 or 5$
  2. #27
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Viton is perfectly acceptable.
  3. #28
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    Stick with the Viton.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  4. #29
    Jun 2013
    04 330Ci
    so VCG and Check valve have been ordered Hopefully will be able to install on the upcoming weekend. will be ordering the DISA kit and possibly a new CCV, I have only found trace amounts of oil in my old one so I may just try to clean it out.
  5. #30
    Jun 2013
    04 330Ci
    Check valve installed waiting on VCG took the old one out today and its very oily. Good indicators and thanks for all the help guys she shohld be up and running in no time.
  6. #31
    dworthy's Avatar
    Nov 2010
    Glad to help.
    The internals look very nice, as you will get the golden coloring from the extended oil changes.
    The wagon when I did the valve cover gasket a couple of years ago.
    Darin
    Current:
    Past:
    M-Flight Member
  7. #32
    Jun 2013
    04 330Ci
    Thats good to hear and I actually did not know that, I was actually a little concerned about the colour. But thats relieving
  8. #33
    Jun 2013
    04 330Ci
    So I got the secondary air pump check valve installed and the VCG. I started and ran the car for about an hour as its not licensed to be on the road yet I cant drive it.
    I am still getting the P1429 code, P0300, P0306, and P0305. Also got a new code P0040 and P0444. I believe the P0444 is just two vacuum hoses that i swapped around in the wrong place. but the P0040 has me stumped and the P1429 as well. Why am I still getting white smoke out of the exhaust, and misfires?
  9. #34
    Jun 2013
    04 330Ci
    Okay so cleared the P0040 and the P0444. Was just a mixup of wiring. Now im still recieving P0300 P0306 and P0304 so the misfire jumped from 5-4 i did switch coils last night 6 went to 4 and 5 went to 3. im still getting alot of whitish grey smoke especially when throttle is applied. Also still have a p1429 which is most likely the secondary air pump from the check valve going bad.
  10. #35
    Jun 2013
    04 330Ci
    a lot of updates this weekend but i checked the ccv hose that i had originally found oil in its the hose that leads directly to the valve cover and im finding brown burnt oil residue now after cleaning it so I believe im going to buy the new CCV and air pump and see if I still have any codes. If im still getting a misfire code I think it will be time to bring her to the local indy for a diagnosis regretfully as I realllly wanted to do it all myself to learn.
  11. #36
    Dec 2013
    Chicagoland area
    EXOTICS
    Check fuel pressure with a FPG at fuel rail Schrader Valve.
    It seems codes are present only at bank #2,
    so focus on them.
  12. #37
    Jun 2013
    04 330Ci
    Cant i use torque pro to find the fuel pressure? Or do I need to go buy a FPG
  13. #38
    Dec 2013
    Chicagoland area
    EXOTICS
    From my experience, I don't think Torque Pro can monitor Fuel Pressure.
    In the states, most autoparts stores rent out the FPG,
    but you're in Canada.
    P1429 would point to the Leak Diagnosis Pump in the Fuel tank Evap System,
    but first check and clean connections/hoses displaying corrosion at pump.
  14. #39
    Jun 2013
    04 330Ci
    I went to BMW Toronto today and asked about the P1429 code and the tech there said its a vacuum pump code so he agreed with the secondary air pump. So I'm going to try getting the secondary air pump replaced to clear that code then hopefully only have the CCV and misfires to deal with.
  15. #40
    Dec 2013
    Chicagoland area
    EXOTICS
    P1429 can be misleading, as it is a generic OBD2 P-code,
    Not an actual BMW error code, obtained with BMW specific scan tool/software.
    From my research and experience that code can point to several items,
    so my suggestion is not to replace any pump just yet, but apply contact cleaner to electrical connections.
    Check for clean non-corroded connections at:
    • Leak Diagnosis Pump in the Fuel tank Evap System
    • Secondary Air Pump
    • Evap Canister Purge Control Valve
    • In a nutshell, a P0040 code means that the vehicle's computer (the PCM or powertrain control module) has detected that the first O2 oxygen sensors downstream from the engine have swapped wiring. The vehicle's PCM uses the oxygen sensor readings to adjust how much fuel to inject into the engine for most efficient operation. The PCM monitors the engine sensor readings and if for example it puts more fuel into bank 2 of the engine but then sees that the bank 1 oxygen sensor is reacting instead of bank 2, that is the type of thing that triggers this code. For this DTC, the first O2 oxygen sensor that is in the exhaust manifold or downstream from it is the sensor #1. It will be upstream from the catalytic converter.
  16. #41
    Jun 2013
    04 330Ci
    Perfect, okay I will check these connections before buying anything. Will update once I have checked the fuel pressure and the connections.
  17. #42
    Jun 2013
    04 330Ci
    This is the smoke coming out of my exhaust. You guys agree on CCV?
  18. #43
    Dec 2013
    Chicagoland area
    EXOTICS
    IF - you have excessive oil consumption,
    and heavy tailpipe smoke,
    and CCV system has never been replaced,
    and it is aged at 255KM,
    YES - I would replace with a refresh kit.
    https://www.fcpeuro.com/products/bmw...-m54b30coldkit
  19. #44
    Jun 2013
    04 330Ci
    Okay just douible checking before I buy.
  20. #45
    dworthy's Avatar
    Nov 2010
    The CCV is a wearable item like a belt. I typically recommend for it to be replaced every 10 years or 125k miles. It is made out of plastic, and over time it will get brittle and break. Since you live in a Cold weather location, be sure to get this one I have attached. Now if you want to replace the dipstick tube that is up to you. I have, and the dipstick likes to get caught on the lower wall as I pull it out. Or you can clean the heck out of the original and hope it continues to work properly.
    Attached Files Attached Files
    Darin
    Current:
    Past:
    M-Flight Member
  21. #46
    Jun 2013
    04 330Ci
    So at 255k I'm right at your recommendation for a replacement. Will replace CCV next. I have no intention of driving the car in the winter so do I still need cold weather kit?
  22. #47
    Jun 2013
    04 330Ci
    Cold weather CCV came in today. Will update again after it is installed this weekend.
  23. #48
    Dec 2013
    Chicagoland area
    EXOTICS
    Kool, looking forward to your results.
  24. #49
    Jun 2013
    04 330Ci
    so I got the new ccv in today and no improvement in engine performance I let it run and revved it for about an hour and it seems like the oil just gets worse after revving.
    I am still only getting multiple misfire code with cylinder 4 and 6 misfiring and the p1429. I've kind of gotten stumped Now could it be the seal pins?
  25. #50
    Jun 2013
    04 330Ci
  1. 95 E36 - CCV question.. Blue Smoke :-/
    By jg727211 in forum 1991 - 1999 (E36)
    Last Post: 09-12-2011, 12:08 PM
  2. CCV Question
    By Cool 530i in forum 1996 - 2003 (E39)
    Last Post: 11-21-2009, 07:57 AM
  3. 1986 325es - PCV / CCV Questions
    By Bailey228 in forum 1983 - 1991 (E30)
    Last Post: 03-07-2009, 12:58 PM
  4. PCV/CCV Question
    By dmore777 in forum 1996 - 2003 (E39)
    Last Post: 11-26-2008, 12:18 AM
  5. CCV Questions?
    By fifthand in forum 1996 - 2003 (E39)
    Last Post: 01-29-2008, 01:17 AM
